How to run forEach in AMD style?
1529
02-04-2014 10:03 AM
LeiZhou
I want to create a checkbox in my left pane.  I try to understand the codes from the following sample,
http://developers.arcgis.com/javascript/sandbox/sandbox.html?sample=widget_legendvisible
It uses legacy code instead of AMD style.  I try to code in AMR mode e.g., use array.forEach() to replace dojo.forEach, But it does not workout.  Could you please have a look at my codes and give me some suggestion? Here is my code below: Thank you!
require(["esri/map",                "esri/geometry/Extent",                "esri/dijit/OverviewMap",                "esri/dijit/BasemapGallery",                "esri/arcgis/utils",                "esri/dijit/HomeButton",                "esri/layers/ArcGISTiledMapServiceLayer",                "esri/layers/ArcGISDynamicMapServiceLayer",                "esri/dijit/Legend",                "esri/dijit/Popup",                "esri/layers/FeatureLayer",                "esri/InfoTemplate",                 "dojo/dom",                "dojo/dom-construct",                "dojo/dom-class",                "dojo/_base/array",                "dojo/on",                "dojo/parser",                "dijit/registry",                "dijit/form/CheckBox",                "dijit/layout/BorderContainer",                "dijit/layout/ContentPane",                "dijit/TitlePane",                "dojo/domReady!"],           function (Map,                     Extent,                     OverviewMap,                     BasemapGallery,                     arcgisUtils,                     HomeButton,                     ArcGISTiledMapServiceLayer,                     ArcGISDynamicMapServiceLayer,                     Legend,                     Popup,                     FeatureLayer,                     InfoTemplate,                       dom,                     domConstruct,                     domClass,                     arrayUtils,                     on,                     parser,                     registry,                     CheckBox                     ){                            var map = new Map("mapDiv", {                   zoom: 3,                   basemap: "streets",                   sliderStyle: "large",                   sliderPosition:"top-right",                   logo: true,                   nav:false,                   navigationMode: 'css-transforms',                   autoResize: true,                                  });                                                         var dynaLayer1 = new ArcGISDynamicMapServiceLayer                   ("http://server.arcgisonline.com/arcgis/rest/services/Demographics/USA_Diversity_Index/MapServer",               {                   opacity: 0.8               });                              var dynaLayer2 = new ArcGISDynamicMapServiceLayer                   ("http://server.arcgisonline.com/arcgis/rest/services/Demographics/USA_Median_Age/MapServer",               {                   opacity: 0.8               });                //Add a legend               var layerInfo;               map.on("layers-add-result", function (evt) {                   layerInfo = arrayUtils.map(evt.layers, function (layer, index) {                       return { layer: layer.layer, title: layer.layer.name };                   });                                                        if (layerInfo.length > 0) {                       var legendDijit = new Legend({                           map: map,                           layerInfos: layerInfo                       }, "legendDiv");                       legendDijit.startup();                   }               });                map.addLayers([dynaLayer1, dynaLayer2]);                                  //Add a checkbox               var cb;               map.on("layers-add-result", function (results) {                    array.forEach(layerInfo, function (layer) {                       var layerName = layer.title;                       var checkBox = new CheckBox({                           name: "checkBox" + layer.layer.id,                           value: layer.layer.id,                           checked: layer.layer.visible,                           onChange: function (evt) {                               var clayer = map.getLayer(this.value);                               clayer.setVisibility(!clayer.visible);                               this.checked = clayer.visible;                           }                       }); //checkbox ends                   }); // forEach ends                });                var thinger = domConstruct.toDom("checkBox ");               domConstruct.place(thinger, dom.byId("toggle"), "after"); //toggle is the div id to put checkbox
KenBuja
MVP Esteemed Contributor
You're using array.forEach in your code, but in the function, you're assigning the alias "arrayUtils" for the array module "dojo/_base/array".
Try using "arrayUtils.forEach" instead. There was a similar question where I replied with a Fiddle that is written in AMD style.
KenBuja
LeiZhou
Thank you very much!
