How to replace watchUtils.whenFalseOnce to the equivalent in reactiveUtils
2162
01-11-2023 03:14 AM
MarceloRosensaft
Hello,
We have a code chunk that works - taken from a post by @RobErt Scheitlin, but uses watchUtils which is deprecated.
watchUtils.whenFalse(view, 'stationary', (evt) => {
        if (!view.stationary) {
            watchUtils.whenTrueOnce(view, 'stationary', function (evt) {
                console.log(view.extent);
        } else {
            watchUtils.whenFalseOnce(view, 'interacting', function (evt) {
How should we convert it to using the reactiveUtils tools?
Thank you in advance,
Marcelo
ReneRubalcava
Esri Frequent Contributor
The reactiveUtils have an option object you can provide where you can set "once" to true.
https://developers.arcgis.com/javascript/latest/api-reference/esri-core-reactiveUtils.html#ReactiveL...
Your above code snippet would look something like this, but the way you have it written, the else is unreachable, maybe the main is watch and not whenFalse?
	when(
		() => !view.stationary,
			console.log("view stationary is: ", view.stationary);
			when(
				() => view.stationary,
				() => console.log("view is now stationary"),
				{ once: true }
Here is a codepen with both options.
https://codepen.io/odoe/pen/zYLwKGb?editors=0010
ReneRubalcava
	when(
			when(
				{ once: true }
MarceloRosensaft
Thank you very much!
Your suggested option seems to be what I need.
I'm counting the features for each layer in the view and I have to count again every time the view changes. Today I do it with layerView.watch('updating'... for every layer and I also catch separately the visibility of the layers since the layerView doen't update when the layer not visible. With your option everything will be simpler. I'm starting to put it in my code.
Thanks again!
Marcelo
