How to remove  and reorder layers from TOC widget?
1228
06-01-2014 11:06 PM
GauriDeshmukh
How should I access the layers or select layers to remove or reorder.I am using TOC widget by nliu. But I want to add functionality to remove layers similar to arcmap(on right click remove or any other way).
JeffPace
The TOC widget is just a representation of map.layers
You can remove and reorder them using map.addLayer, map.reorderLayer, and then calling TOC.refresh() as necessary.
GauriDeshmukh
But how should I select or access the layer from toc to remove or refresh. I want remove or reorder layers from toc only.
GauriDeshmukh
I guess we will use   "   toc.on('toc-node-checked', function(evt){}   "   event to get the selected ayers(for removing or reordering).
But not sure as unable to do it.
