How to query and select three shapefile under one name as one unique value
2109
08-04-2017 12:40 AM
FaryalSafdar
i am encountering problem with query i have to select three shapfile under one name as one unique value. it worked in arcmap but it does not work with arcgis javascrip api. my query is
esriRequest({
              url: "http://localhost:6080/arcgis/rest/services/........./query?where=Name ='" + id.toString() + "'&outFields=Soil&returnGeometry=false&orderByFields=Soil&returnDistinctValues= true&f=json",
              content: {
                f: 'json'
              handleAs: 'json',
              callbackParamName: 'callback',
              timeout: 15000
            }).then(lang.hitch(this, function(response) {
              var store2 = new Memory({
                data: []
              });but in coding when i have applied query it populate combobox like this in below image could anyone tell me what i am doing wrong?
RobertScheitlin__GISP
Faryal,
   So what is returned when you just paste a test url in your browser like:
http: //localhost:6080/arcgis/rest/services/........./query?where=Name ='.........'&outFields=Soil&returnGeometry=false&orderByFields=Soil&returnDistinctValues= true&f=json
Do you get three values back or just one. If you get there then the query or underlying data is your issue.
FaryalSafdar
{"displayFieldName":"Id","fieldAliases":{"Soil":"Soil"},"fields":[{"name":"Soil","type":"esriFieldTypeString","alias":"Soil","length":50}],"features":[]}
it returns this.
Faryal,
   The query did not return any features. So did you put an appropriate value in the
Name='.........' portion of the url?
FaryalSafdar
it returns this when i put query in the query form of layer
"displayFieldName": "Id",
"fieldAliases": {
"Soil": "Soil"
"fields": [
"name": "Soil",
"type": "esriFieldTypeString",
"alias": "Soil
"length": 50
"features": [
"attributes": {
"Soil": "Soil Map"
"attributes": {
"Soil": "Soil Map"
"attributes": {
"Soil": "Soil Map"
Faryal,
  That is very strange that your server is not returning distinct values for the SOIL field. When I do this type of query on my ArcGIS Server I only get distinct values:
http: //gis.calhouncounty.org/arcgis2/rest/services/ParcelViewer/MapServer/67/query?where=NAME+LIKE+...
Results:
 "displayFieldName": "PARCEL_NUMBER",
 "fieldAliases": {
  "SUBDIVISION": "Subdivision"
 "fields": [
   "name": "SUBDIVISION",
   "alias": "Subdivision",
   "length": 12
 "features": [
   "attributes": {
    "SUBDIVISION": ""
   "attributes": {
    "SUBDIVISION": "BD1A"
   "attributes": {
    "SUBDIVISION": "C0"
   "attributes": {
    "SUBDIVISION": "GC3A"
   "attributes": {
    "SUBDIVISION": "GRVSB"
   "attributes": {
    "SUBDIVISION": "HT1"
   "attributes": {
    "SUBDIVISION": "JOE"
   "attributes": {
    "SUBDIVISION": "LE0"
   "attributes": {
    "SUBDIVISION": "LEHA"
   "attributes": {
    "SUBDIVISION": "LLS11"
   "attributes": {
    "SUBDIVISION": "LP"
   "attributes": {
    "SUBDIVISION": "LTC"
   "attributes": {
    "SUBDIVISION": "P7"
   "attributes": {
    "SUBDIVISION": "SHH0"
So you may need to contact esri tech support if you are currently under maintenance. If not then you can use some JS code to get the distinct values from the results on the client side:
function getDistinctValues(array) {
        var flags = [],
          output = [],
          l = array.length,
          i;
        for (i = 0; i < l; i++) {
          if (flags[array[i]]){
            continue;
          flags[array[i]] = true;
          if (array[i] === ' ') {
            continue;
          var uVal;
          if (array[i] === null) {
            uVal = {
              code: 'null',
          } else {
            uVal = {
              code: array[i],
          output.push(uVal);
        return sortByKey(output, "code");
        function sortByKey(array, key) {
          return array.sort(function (a, b) {
            var x = a[key];
            var y = b[key];
            if (typeof x == "string") {
              x = x.toLowerCase().trim();
              y = y.toLowerCase().trim();
            return ((x < y) ? -1 : ((x > y) ? 1 : 0));
