How to prevent Map.Redraw from using last drawn symbol
5657
6
01-20-2015 12:51 PM
MorganKeene
Hello,
   I have recreated this draw tool found in the ArcGIS API for flex http://www.arcgis.com/home/item.html?id=91a0014160fc4a9caadc2c7fd7089c1b
It is fully functional the only problem is when you pan or zoom in and out the map calls a graphics.redraw and redraws all graphics on the map using the last set properties which overwrites other symbols fill colors etc.
I am trying to find a way to keep the graphics the same whenever I pan or zoom.
TimWitt2
Morgan,
it is tough to help without seeing your code. Do you have a jsfiddle or something?
Tim
MorganKeene
      var tb;
      require([
        "esri/map", "esri/toolbars/draw",
        "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/TextSymbol",
        "esri/symbols/SimpleFillSymbol", "esri/symbols/CartographicLineSymbol", "esri/tasks/GeometryService", "esri/dijit/Measurement",
        "esri/graphic",
        "esri/Color", "dojo/dom", "dojo/on", "dojo/domReady!"
      ], function(
        Map, Draw,
        SimpleMarkerSymbol, SimpleLineSymbol, TextSymbol,
        SimpleFillSymbol, CartographicLineSymbol, GeometryService, Measurement,
        Graphic,
        Color, dom, on
        esriConfig.defaults.geometryService = new GeometryService("http://mapservices.ssmic.com/production/rest/services/Utilities/Geometry/GeometryServer");
  // set the map property to be the same as the map initialized in the index.html
        map = map
        map.on("load", initToolbar); // on the map load, call initToolbar
  //sets the properties of the measurement widget then enables it.
  var measurement = new Measurement({
  map: map,
  lineSymbol: lineSymbol,
  pointSymbol: markerSymbol
  }, dom.byId("measurementDiv")); measurement.startup();
           var markerSymbol = new SimpleMarkerSymbol();
    var lineSymbol = new CartographicLineSymbol();
    var fillSymbol = new SimpleFillSymbol();
  // disables all the proprerties for every draw tool properties
  // they are disabled because each tool uses a different set of properties
  function disableAllProperties(){
   document.getElementById("colorPickerDiv").style.display = "none";
   document.getElementById("outlinePickerDiv").style.display = "none";
   document.getElementById("spinnerDiv").style.display = "none";
   document.getElementById("widthDiv").style.display = "none";
   document.getElementById("spinnerLabel").style.display = "none";
   document.getElementById("sizeSpinner").style.display = "none";
   document.getElementById("pointIconDiv").style.display = "none";
   document.getElementById("lineSymbolDiv").style.display = "none";
   document.getElementById("polyFillDiv").style.display = "none";
   document.getElementById("textInput").style.display = "none";
   document.getElementById("textBox").style.display = "none";
   document.getElementById("fontLabel").style.display = "none";
   document.getElementById("fontSelect").style.display = "none";
   document.getElementById("ck-button").style.display = "none";
  //set the clear graphics button to not visible. it is not included in disableAllProperties because it will make
  // the clear label dissapear at incorrect times.
  document.getElementById("clearGraphic").style.display = "none";
        function initToolbar() {
          tb = new Draw(map);
          tb.on("draw-end", addGraphic);
   document.getElementById("measurementDiv").style.display = "none";
   //disable all properties for each draw symbol so we can set the visibility for only the properties we need
   disableAllProperties();
          // event delegation so a click handler is not
          // needed for each individual button
          on(dom.byId("DrawDiv"), "click", function(evt) {
            if (!( evt.target.id === "Point" || evt.target.id == "Polyline" || evt.target.id == "FreehandPolyline" || evt.target.id == "Extent" || evt.target.id == "Circle" || evt.target.id == "Ellipse" || evt.target.id == "Polygon" || evt.target.id == "FreehandPolygon" || evt.target.id == "text")) {
              return;
            var tool = evt.target.id.toLowerCase();
  //here we will add the properties to the selected tool
  if (tool === "point" || tool === "multipoint"){
  // if the point has been selected, enable all the properties as the pointer uses them all.
   document.getElementById("colorPickerDiv").style.display = "inline-block";
   document.getElementById("outlinePickerDiv").style.display = "inline-block";
   document.getElementById("spinnerDiv").style.display = "inline-block";
   document.getElementById("widthDiv").style.display = "inline-block";
   document.getElementById("spinnerLabel").style.display = "inline-block";
   document.getElementById("sizeSpinner").style.display = "inline-block";
   document.getElementById("pointIconDiv").style.display = "inline-block";
  var symbolToUse = $("#pointIcon").val();
  markerSymbol.setColor($("#colorPicker").val());
  markerSymbol.setSize($("#sizeSpinner").val());
  markerSymbol.setOutline(new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, $("#outlinePicker").val(), $("#widthSpinner").val())); // this sets the outline of the icon, the default is a thin black line
  //there is no way to set the symbol style passing it as a variable so I will check the dropdown list
  //and depending on the selected value, set the symbol style
  if (symbolToUse === "STYLE_CIRCLE"){
  markerSymbol.setStyle(SimpleMarkerSymbol.STYLE_CIRCLE);
  } else if(symbolToUse === "STYLE_CROSS"){
  markerSymbol.setStyle(SimpleMarkerSymbol.STYLE_CROSS);
  }else if(symbolToUse === "STYLE_DIAMOND"){
  markerSymbol.setStyle(SimpleMarkerSymbol.STYLE_DIAMOND);
  }else if(symbolToUse === "STYLE_SQUARE"){
  markerSymbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
  }else{
  markerSymbol.setStyle(SimpleMarkerSymbol.STYLE_X);
  } else if (tool === "line" || tool === "polyline" || tool === "freehandpolyline"){
  //hide all the properties initially
  // enable the properties specific to the line or polyline.
  document.getElementById("lineSymbolDiv").style.display = "inline-block";
  var lineSymbolToUse = $("#lineSymbolIcon").val();
  if (lineSymbolToUse === "STYLE_SOLID"){
  lineSymbol = new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color($("#colorPicker").val()), $("#widthSpinner").val());
  } else if(lineSymbolToUse === "STYLE_DASH"){
  lineSymbol = new SimpleLineSymbol( SimpleLineSymbol.STYLE_DASH, new Color($("#colorPicker").val()), $("#widthSpinner").val());
  }else if(lineSymbolToUse === "STYLE_DOT"){
  lineSymbol = new SimpleLineSymbol( SimpleLineSymbol.STYLE_DOT, new Color($("#colorPicker").val()), $("#widthSpinner").val());
  }else if(lineSymbolToUse === "STYLE_DASHDOT"){
  lineSymbol = new SimpleLineSymbol( SimpleLineSymbol.STYLE_DASHDOT, new Color($("#colorPicker").val()), $("#widthSpinner").val());
  }else{
  lineSymbol = new SimpleLineSymbol( SimpleLineSymbol.STYLE_DASHDOTDOT, new Color($("#colorPicker").val()), $("#widthSpinner").val());
  else if (tool === "text"){
  //hide all properties
  //enable the properties specific to the text tool
  document.getElementById("textInput").style.display = "inline-block";
     document.getElementById("textBox").style.display = "inline-block";
     document.getElementById("fontLabel").style.display = "inline-block";
     document.getElementById("fontSelect").style.display = "inline-block";
  document.getElementById("ck-button").style.display = "inline-block";
  mapClick = map.on("click", drawTextSymbol);
  else{
  // for all other shapes , set the properties here
  // enable the properties specific to the freehandPolyline.
  document.getElementById("polyFillDiv").style.display = "inline-block";
  // here we get the value from the drop down list to set the graphic fill of the symbol
  var fillSymbolToUse = $("#polyFill").val();
  if (fillSymbolToUse === "STYLE_SOLID"){
  fillSymbol.setStyle(SimpleFillSymbol.STYLE_SOLID);
  } else if(fillSymbolToUse === "STYLE_BACKWARD_DIAGONAL"){
  fillSymbol.setStyle(SimpleFillSymbol.STYLE_BACKWARD_DIAGONAL);
  }else if(fillSymbolToUse === "STYLE_CROSS"){
  fillSymbol.setStyle(SimpleFillSymbol.STYLE_CROSS);
  }else if(fillSymbolToUse === "STYLE_FORWARD_DIAGONAL"){
  fillSymbol.setStyle(SimpleFillSymbol.STYLE_FORWARD_DIAGONAL);
  }else if(fillSymbolToUse === "STYLE_HORIZONTAL"){
  fillSymbol.setStyle(SimpleFillSymbol.STYLE_HORIZONTAL);
  }else{
  fillSymbol.setStyle(SimpleFillSymbol.STYLE_VERTICAL);
  // here we get the value from the drop down list to set the outline symbol type
  var fillOutlineSymbolToUse = $("#lineSymbolIcon").val();
  if (fillOutlineSymbolToUse === "STYLE_SOLID"){
  fillSymbol.setOutline(new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, $("#outlinePicker").val(), $("#widthSpinner").val()));
  } else if(fillOutlineSymbolToUse === "STYLE_DASH"){
  fillSymbol.setOutline(new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASH, $("#outlinePicker").val(), $("#widthSpinner").val()));
  }else if(fillOutlineSymbolToUse === "STYLE_DOT"){
  fillSymbol.setOutline(new SimpleLineSymbol(SimpleLineSymbol.STYLE_DOT, $("#outlinePicker").val(), $("#widthSpinner").val()));
  }else if(fillOutlineSymbolToUse === "STYLE_DASHDOT"){
  fillSymbol.setOutline(new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT, $("#outlinePicker").val(), $("#widthSpinner").val()));
  }else{
  fillSymbol.setOutline(new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOTDOT, $("#outlinePicker").val(), $("#widthSpinner").val()));
  fillSymbol.setColor($("#colorPicker").val());
            tb.activate(tool);
        function addGraphic(evt) {
          //deactivate the toolbar
          tb.deactivate();
          map.enableMapNavigation();
          // figure out which symbol to use
   // the color and outline Color are set here because a bug was being caused when you would try and print the graphics the user placed on map.
          var symbol;
          if ( evt.geometry.type === "point" || evt.geometry.type === "multipoint") {
            symbol = markerSymbol;
  markerSymbol.setColor(new Color($("#colorPicker").val()));
  markerSymbol.setOutline(new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color($("#outlinePicker").val()), $("#widthSpinner").val()));
          } else if ( evt.geometry.type === "line" || evt.geometry.type === "polyline") {
            symbol = lineSymbol
          else {
            symbol = fillSymbol;
  fillSymbol.setColor(new Color($("#colorPicker").val()));
  fillSymbol.setOutline(new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color($("#outlinePicker").val()), $("#widthSpinner").val()));
          map.graphics.add(new Graphic(evt.geometry, symbol));
   document.getElementById("clearGraphic").style.display = "block";
MorganKeene
no, sorry I do not , I can probably paste the draw code in here
TimWitt2
Morgan,
I know this is not what you asked, but check out my draw widget I created for javascript.
Javascript API - Advanced Draw widget
Maybe you don't need to re-invent the wheel
Tim
MorganKeene
I like what you have done here, though the only problem is that I cannot implement this right now there has already been too much time allocated to this and customized too much. I'll just find a way to make this work somehow. thanks for your suggestion and time
MorganKeene
aside from all the extra added features you've implemented, the only difference I see is that you create variables to hold your parameters , then you initialize each marker type in the add graphic function whereas I create a global variable and assign its properties as I do checks on my html elements then draw the symbol. I will re construct my code to preform more similar to yours as where you create the markers just before you add them to the graphic layer.
