How to open an InfoTemplate window and keep opened?
3264
09-12-2014 01:01 AM
AimanCall
Hi ,
I can't find any solution to keep InfoTemplate window opened once user clicks on the marker. User should be able to close it using "X" button only - if click on another marker, the previous window should still stay opened - so two or more windows should be opened at the same time.
I hope it make sense to you.
All suggestions very welcome.
DanPatterson_Retired
You will need to edit this post and provide appropriate tags and select an appropriate place to direct it otherwise the question will become misdirected
AimanCall
thanks for your feedback. I have no idea about tags and place. Looks like sooner I quit relation with esri framework - better. I think it is better to go back to google map API - at least I get help on forums. Thank you anyway, you've helped me to choose better for me.
The problem is that no on know what infotemplate is and the closest link is to javascript, so the place would be something like "ArcGIS API for javascript" or one of the other APIs Only you know what portion of the Arc* suite you are working with.  When you click on Places, select Spaces to see the breakdown
