How to not return ring information from service
1198
12-15-2022 09:34 AM
UgurcanErkal
Hi guys,
I'm new to esri environment, and so far everything is going well. But what I'm curious about is; whether there is a way to exclude ring information from an API call or not. Even though I pass the returnGeometry as false, it sends me the geometry information.
JayakumarPD
Hi, I dont know which interface you are using to perform this,
if you put geometry=false, it will not give you the geometry.  Esri has default query window, you can try.
Snapshot enclosed.
