How to make ' .mxd'  file of a sample,from the API called Temporal Renderer - Class B
1166
08-21-2012 06:49 PM
lijack
How to make ' .mxd'  file of  this sample: http://help.arcgis.com/en/webapi/javascript/arcgis/demos/renderer/renderer_temporalClassBreaks.html .especially the time information.
thanks.
lijack
No one reply?
JohnGravois
It is not possible to create an MXD file using information supplied via map services and hosted in a Javascript application.  You need to have access to the raw data used when the service was published.
lijack
Data have been published.But it can't work.I think the data format is not correct,So I want to know that what kind of the data format.Thanks
