how to locate using input coordinate latitude langitude
1845
12-06-2016 07:21 PM
nanasyazana
hi, how to code the locate function using input coordinate using openstreetmap. Example in the web is for google map. i want the same function but execute openstreetmap in arcgis.
Example for google map as below:
Google Maps - GPS coordinates, latitude and longitude
thanks,
Regards,
Nana
FC_Basson
MVP Alum
The deafult projection for most Web base maps like OSM is Web Mercator, which is completely different from LatLon geographic coordinate system (GCS).  Have a look at  esri/geometry/webMercatorUtils | API Reference | ArcGIS API for JavaScript 3.18 for converting between geographic and Web Mercator coordinates,
