How to join two scripts to get the desired output?
3463
11-06-2014 06:56 AM
ManjariGoyal
I have two scripts, first script is to geocode the address and second script is to click anywhere in the map and it creates a circle (1.5 Mile radius) from the clicked point. I want  to join these two scripts and the output should be geocode the address and then from the address point draw a circle(which should be static) and get the cell tower points from the feature layer ..
Please let me know the solution as I am fairly new to this language.
SCRIPT ONE:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Find Address</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
    <style>
      html, body {
        height: 100%; width: 100%;
        margin: 0; padding: 0;
      #map{
        padding:0;
        border:solid 1px #343642;
        margin:5px 5px 5px 0px;
      #leftPane{
        width:20%;
        border-top: solid 1px #343642;
        border-left: solid 1px #343642;
        border-bottom: solid 1px #343642;
        margin:5px 0px 5px 5px;
        color: #343642;
        font:100% Georgia,"Times New Roman",Times,serif;
        /*letter-spacing: 0.05em;*/
     </style>
    <script src="http://js.arcgis.com/3.11/"></script>
    <script>
      var map, locator;
      require([
        "esri/map", "esri/tasks/locator", "esri/graphic",
        "esri/InfoTemplate", "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/Font", "esri/symbols/TextSymbol",
        "dojo/_base/array", "esri/Color",
        "dojo/number", "dojo/parser", "dojo/dom", "dijit/registry",
        "dijit/form/Button", "dijit/form/Textarea",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        Map, Locator, Graphic,
        InfoTemplate, SimpleMarkerSymbol,
        Font, TextSymbol,
        arrayUtils, Color,
        number, parser, dom, registry
        parser.parse();
        map = new Map("map", {
          basemap: "streets",
          center: [-93.5, 41.431],
          zoom: 5
        locator = new Locator("http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer");
        locator.on("address-to-locations-complete", showResults);
        // listen for button click then geocode
        registry.byId("locate").on("click", locate);
        map.infoWindow.resize(200,125);
        function locate() {
          map.graphics.clear();
          var address = {
            "SingleLine": dom.byId("address").value
          locator.outSpatialReference = map.spatialReference;
          var options = {
            address: address,
            outFields: ["Loc_name"]
          locator.addressToLocations(options);
        function showResults(evt) {
          var symbol = new SimpleMarkerSymbol();
          var infoTemplate = new InfoTemplate(
            "Location",
            "Address: ${address}<br />Score: ${score}<br />Source locator: ${locatorName}"
          symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
          symbol.setColor(new Color([153,0,51,0.75]));
          var geom;
          arrayUtils.every(evt.addresses, function(candidate) {
            console.log(candidate.score);
            if (candidate.score > 80) {
              console.log(candidate.location);
              var attributes = {
                address: candidate.address,
                score: candidate.score,
                locatorName: candidate.attributes.Loc_name
              geom = candidate.location;
              var graphic = new Graphic(geom, symbol, attributes, infoTemplate);
              //add a graphic to the map at the geocoded location
              map.graphics.add(graphic);
              //add a text symbol to the map listing the location of the matched address.
              var displayText = candidate.address;
              var font = new Font(
                "12pt",
                Font.STYLE_NORMAL,
                Font.VARIANT_NORMAL,
                Font.WEIGHT_BOLD,
                "Helvetica"
              var textSymbol = new TextSymbol(
                displayText,
                font,
                new Color("#666633")
              textSymbol.setOffset(0,8);
              map.graphics.add(new Graphic(geom, textSymbol));
              return false; //break out of loop after one candidate with score greater  than 80 is found.
          if ( geom !== undefined ) {
            map.centerAndZoom(geom, 12);
     var map, locator;
  /*require([
        "esri/map", "esri/layers/FeatureLayer",
        "esri/tasks/query", "esri/geometry/Circle",
        "esri/graphic", "esri/InfoTemplate", "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/renderers/SimpleRenderer",
        "esri/config", "esri/Color", "dojo/dom", "dojo/domReady!", "esri/tasks/locator", "esri.arcgis.utils", "dijit.form.Button",
        "dijit.layout.ContentPane", "dijit.layout.BorderContainer", "esri/symbols/Font", "esri/symbols/TextSymbol",
        "dojo/_base/array", "dojo/number", "dojo/parser", "dijit/registry", "dijit/form/Button", "dijit/form/Textarea"
      function(
         Map, FeatureLayer,
         Query, Circle,
         Graphic, InfoTemplate, SimpleMarkerSymbol,
         SimpleLineSymbol, SimpleFillSymbol, SimpleRenderer,
         esriConfig, Color, dom
        // use a proxy page if a URL generated by this page is greater than 2000 characters
        // this should not be needed as nearly all query & select functions are performed on the client
        esriConfig.defaults.io.proxyUrl = "/proxy/";
          basemap: "streets",
          zoom: 5
  //add the census block points in on demand mode. Note that an info template has been defined so when
       //selected features are clicked a popup window will appear displaying the content defined in the info template.
  var featureLayer = new FeatureLayer
  ("https://map layer",{
          //infoTemplate: new InfoTemplate("CascadeID: ${SOURCE_CAS}", "${*}"),
          infoTemplate: new InfoTemplate("Cell Towers"),
          outFields: ["SOURCE_CAS","SOURCE_SIT","SOURCE_OEM", "SOURCE_MAR", "SOURCE_LEA", "SOURCE_TOT"]
     // selection symbol used to draw the selected census block points within the buffer polygon
        SimpleMarkerSymbol.STYLE_CIRCLE,
        12,
        new SimpleLineSymbol(
        SimpleLineSymbol.STYLE_NULL,
        new Color([247, 34, 101, 0.9]),
       new Color([207, 34, 171, 0.5])
     featureLayer.setSelectionSymbol(symbol);
  //make unselected features invisible
        var nullSymbol = new SimpleMarkerSymbol().setSize(0);
        featureLayer.setRenderer(new SimpleRenderer(nullSymbol));
        map.addLayer(featureLayer);
        var circleSymb = new SimpleFillSymbol(
        SimpleFillSymbol.STYLE_NULL,
        SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
        new Color([105, 105, 105]),
       ), new Color([255, 255, 0, 0.25])
        var circle;
    //when the map is clicked create a buffer around the click point of the specified distance.
  map.on("click", function(evt){
        circle = new Circle({
        center: evt.mapPoint,
        geodesic: true,
        radius: 1.5,
        radiusUnit: "esriMiles"
          //map.infoWindow.hide();
          var graphic = new Graphic(circle, circleSymb);
    var query = new Query();
          query.geometry = circle.getExtent();
     //use a fast bounding box query. will only go to the server if bounding box is outside of the visible map
          featureLayer.queryFeatures(query, selectInBuffer);
  function selectInBuffer(response){
        var feature;
        var features = response.features;
        var inBuffer = [];
     //filter out features that are not actually in buffer, since we got all points in the buffer's bounding box
        for (var i = 0; i < features.length; i++) {
          feature = features;
              if(circle.contains(feature.geometry)){
                  inBuffer.push(feature.attributes[featureLayer.objectIdField]);
        query.objectIds = inBuffer;
   //use a fast objectIds selection query (should not need to go to the server)
          featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results){
            var totalPopulation = sumPopulation(results);
            var r = "";
            r = "<b>The total Census Block population within the buffer is <i>" + totalPopulation + "</i>.</b>";
            dom.byId("messages").innerHTML = r;
              function sumPopulation(features) {
         var popTotal = 0;
        for (var x = 0; x < features.length; x++) {
            popTotal = popTotal + features.attributes["POP2000"];
        return popTotal;
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'sidebar', gutters:false"
         style="width:100%; height:100%;">
      <div id="leftPane"
           data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'left'">
        Enter an address then click the locate button to use a sample address locator to return the location for
        street addresses in the United States.
        <br>
        <textarea id="address">380 New York St, Redlands</textArea>
        <br>
        <button id="locate" data-dojo-type="dijit/form/Button">Locate</button>
      </div>
      <div id="map"
           data-dojo-props="region:'center'">
      </div>
    </div>
  </body>
</html>
SCRIPT TWO:
<!DOCTYPE html>
<html>
  <head>
          on iOS devices-->    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
      <title>Select with feature layer</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/tundra/tundra.css">
  <style>
    html, body, #mapDiv
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
  #messages
        background-color: #fff;
        box-shadow: 0 0 5px #888;
        font-size: 1.1em;
        max-width: 15em;
        padding: 0.5em;
        position: absolute;
        right: 20px;
        top: 20px;
        z-index: 40;
  </style>
  <script>
  var map, locator;
  require([
      function(
         Map, FeatureLayer,
         Query, Circle,
  map = new Map("mapDiv", {
           basemap: "streets",
           center: [-95.249, 38.954],
           zoom: 14,
           slider: false
  //add the cell tower points in on demand mode. Note that an info template has been defined so when
     // selection symbol used to draw the selected cell tower block points within the buffer polygon
        12,
        var circle;
        geodesic: true,
        radius: 1.5,
        var feature;
        var inBuffer = [];
          feature = features;
            var r = "";
         var popTotal = 0;
        return popTotal;
</script>
</head>
<body>
  <span id="messages">Click on the map to select census block points within 1.5 mile.</span>
    <div id="mapDiv"></div>
</body>
</html>
JakeSkinner
Esri Esteemed Contributor
Hi Manjari,
Here is an example of the combined samples:
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
      html, body, #mapDiv {
        padding: 0;
        margin: 0;
        height: 100%;
      #messages{
        font-size: 1.1em;
        max-width: 15em;
        padding: 0.5em;
        position: absolute;
        right: 20px;
        top: 20px;
        z-index: 40;
      #leftPane{
        width:20%;
        color: #343642;
    </style>
    <script>
      var map, candidateLocation;
      require([
        "esri/map", "esri/layers/FeatureLayer", "esri/tasks/locator",
        "dojo/_base/array", "dijit/registry",
        "esri/config", "esri/Color", "dojo/dom", "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/form/Button", "dijit/form/Textarea",
        "dojo/domReady!"
      ], function(
        Map, FeatureLayer, Locator,
        Query, Circle,
        Font, TextSymbol,
        arrayUtils, registry,
        esriConfig, Color, dom, parser
        parser.parse();
          basemap: "streets",
          zoom: 14,
          slider: false
        var featureLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0",{
          infoTemplate: new InfoTemplate("Block: ${BLOCK}", "${*}"),
          outFields: ["POP2000","HOUSEHOLDS","HSE_UNITS", "TRACT", "BLOCK"]
        function locate() {
          var address = {
          var options = {
            address: address,
          console.log(evt);
            "Location",
          var geom;
              candidateLocation = candidate.location;
              var attributes = {
                "16pt",
                Font.STYLE_NORMAL,
                Font.WEIGHT_BOLD,
                "Helvetica"
                displayText,
                font,
            map.centerAndZoom(geom, 15);
          Buffer(candidateLocation);
          12,
        var circle;
        function Buffer(evt){
          console.log(evt);
            center: evt,
            geodesic: true,
            radius: 1,
          var feature;
          var inBuffer = [];
            feature = features;
            var r = "";
          var popTotal = 0;
          return popTotal;
    </script>
  </head>
      <div id="leftPane"
        <br>
        <textarea id="address">W 9th St, Lawrence, KS</textArea>
        <br>
      </div>
      <span id="messages">Click on the map to select census block points within 1 mile.</span>
      <div id="mapDiv" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
      </div>
    </div>
  </body>
</html>
JakeSkinner
Hi Manjari,
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
        padding: 0;
        margin: 0;
        height: 100%;
      #messages{
        font-size: 1.1em;
        max-width: 15em;
        padding: 0.5em;
        position: absolute;
        right: 20px;
        top: 20px;
        z-index: 40;
      #leftPane{
        width:20%;
        color: #343642;
    </style>
    <script>
      require([
        "dojo/domReady!"
      ], function(
        Query, Circle,
        Font, TextSymbol,
        parser.parse();
          basemap: "streets",
          zoom: 14,
          slider: false
        function locate() {
          var address = {
          var options = {
            address: address,
          console.log(evt);
            "Location",
          var geom;
              var attributes = {
                "16pt",
                Font.STYLE_NORMAL,
                Font.WEIGHT_BOLD,
                "Helvetica"
                displayText,
                font,
          12,
        var circle;
          console.log(evt);
            center: evt,
            geodesic: true,
            radius: 1,
          var feature;
          var inBuffer = [];
            feature = features;
            var r = "";
          var popTotal = 0;
          return popTotal;
    </script>
  </head>
      <div id="leftPane"
        <br>
        <br>
      </div>
      </div>
    </div>
  </body>
</html>
ManjariGoyal
Thanks Jake.
