How to insert new record in CodedValueDomain?
1699
08-10-2016 03:51 AM
MihaelVodeb
How to add a new value into CodedValue domain IN sde 10.3.1 from javascript api 3.17 code?
Tags (1)
RobertScheitlin__GISP
Mihael,
  Certain things like managing field domains are limited to ArcGIS desktop or Python and are not available from client side APIs.
JakeSkinner
Esri Esteemed Contributor
Hi Michael,
You can update the service you are working with so that you don't have to republish the data using ArcGIS Desktop.  Take a look at page 'Domains and their values' on page 4 within the following document:
https://blogs.esri.com/esri/arcgis/files/2014/10/How-to-Update-Hosted-Feature-Service-Schemas1.pdf
