How to improve the feature layer renderer performance?
8350
11
01-02-2017 06:27 PM
LeoDeng
When large amounts of points (about 40,000) on the map (no clusters allowed), the pan / zoom operator will pending for a long time.  Is there any way to improve this?
The constraints include:
1. no cluster allowed
2. using arcgis js api 3.X
3. at least 40,000 points
4. no tiles
<!DOCTYPE html>
<html>
    <head>
        <meta charset="utf-8">
        <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
        <title>Students</title>
        <link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
    </head>
    <body>
        <div id="map" style="width: 100%; height: 900px;"></div>
        <script src="https://js.arcgis.com/3.18/"></script>
        <script type="text/javascript">
            require(["esri/map", "esri/layers/FeatureLayer", "esri/symbols/SimpleMarkerSymbol", "esri/renderers/SimpleRenderer", "esri/Color"], function(Map,FeatureLayer,SimpleMarkerSymbol,SimpleRenderer,Color){
                var map = new Map("map", {
                    basemap: "streets",
                    center: [-87.252628,30.639658],
                    zoom: 10,
                    logo: false,
                    showAttribution: false
                var url = "https://services.arcgis.com/a3bwkdJaVo8mjuX0/arcgis/rest/services/Escambia_Students/FeatureServer/0";
                var studentLayer = new FeatureLayer(url,{
                    mode: FeatureLayer.MODE_SNAPSHOT,
                    outFields: ["*"]
                var symbol = new SimpleMarkerSymbol().setColor(new Color("blue")).setSize(6);
                var renderer = new SimpleRenderer(symbol);
                studentLayer.setRenderer(renderer);
                map.addLayers([studentLayer]);
        </script>
    </body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
LeoDeng
Thank you for your advice.
LeoDeng
At last, I choose to override the dojo.shape.Container.remove function.
shape.Container.remove = function(a, c)
{// override the remove
    return this;
It seems better now on map pan operator.  But I don't sure that this will influence others or not.
