How to hide unwanted tools in editor toolbar widget?
7778
15
11-22-2016 09:11 AM
KushendraShah1
I need to customize the editor toolbar widget by hiding the list of unwanted tools for me in editor toolbar widget. Is there way I could get this done deactivating and hiding such tools in javascript or css?. It seems like those tools came as default in editor widget. However I was able to remove the display of some tools/buttons in dropdown like delete, AddToSelection, NewSelection, Attributes, ClearSelection. Here is the remaining buttons/tools that I wanted to hide or remove from the widget for my application and only keep undo/redo button. Appreciate for any help. Thanks
RobertScheitlin__GISP
Kushendra,
   Sure here is a sample that shows how:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Edit rivers and waterbodies</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.18/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
    <style>
      html,body{height:100%;width:100%;margin:0;overflow:hidden;}
      #map{
        padding:0;
      #header{
        font-size: 1.1em;
        font-family: sans-serif;
        padding-left: 1em;
        padding-top:4px;
        color:#660000;
      .templatePicker {
        border: none;
      .dj_ie .infowindow .window .top .right .user .content { position: relative; }
      .dj_ie .simpleInfoWindow .content { position: relative; }
    </style>
    <script src="https://js.arcgis.com/3.18/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/tasks/GeometryService",
        "esri/layers/ArcGISTiledMapServiceLayer",
        "esri/layers/FeatureLayer",
        "esri/Color",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/dijit/editing/Editor",
        "esri/dijit/editing/TemplatePicker",
        "esri/config",
        "dojo/i18n!esri/nls/jsapi",
        "dojo/_base/array", "dojo/parser", "dojo/keys", "dojo/query", "dojo/dom-style",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
        "dojo/domReady!"
      ], function(
        Map, GeometryService,
        ArcGISTiledMapServiceLayer, FeatureLayer,
        Color, SimpleMarkerSymbol, SimpleLineSymbol,
        Editor, TemplatePicker,
        esriConfig, jsapiBundle,
        arrayUtils, parser, keys, query, domStyle
        parser.parse();
        // snapping is enabled for this sample - change the tooltip to reflect this
        jsapiBundle.toolbars.draw.start = jsapiBundle.toolbars.draw.start +  "<br>Press <b>ALT</b> to enable snapping";
        // refer to "Using the Proxy Page" for more information:  https://developers.arcgis.com/javascript/3/jshelp/ags_proxy.html
        esriConfig.defaults.io.proxyUrl = "/proxy/";
        //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications.
        esriConfig.defaults.geometryService = new GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        map = new Map("map", {
          basemap: "satellite",
          center: [-96.541, 38.351],
          zoom: 14,
          slider: false
        map.on("layers-add-result", initEditor);
        //add boundaries and place names
        var labels = new ArcGISTiledMapServiceLayer("https://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer");
        map.addLayer(labels);
        var responsePoints = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/0", {
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ['*']
        var responsePolys = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/2", {
          outFields: ['*']
        map.addLayers([responsePolys, responsePoints]);
        function initEditor(evt) {
          var templateLayers = arrayUtils.map(evt.layers, function(result){
            return result.layer;
          var templatePicker = new TemplatePicker({
            featureLayers: templateLayers,
            grouping: true,
            rows: "auto",
            columns: 3
          }, "templateDiv");
          templatePicker.startup();
          var layers = arrayUtils.map(evt.layers, function(result) {
            return { featureLayer: result.layer };
          var settings = {
            map: map,
            templatePicker: templatePicker,
            layerInfos: layers,
            toolbarVisible: true,
            createOptions: {
              polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ],
              polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON,
                Editor.CREATE_TOOL_CIRCLE,
                Editor.CREATE_TOOL_TRIANGLE,
                Editor.CREATE_TOOL_RECTANGLE
            toolbarOptions: {
              reshapeVisible: false
          var params = { settings: settings };
          var myEditor = new Editor(params, 'editorDiv');
          //define snapping options
          var symbol = new SimpleMarkerSymbol(
            SimpleMarkerSymbol.STYLE_CROSS,
            15,
            new SimpleLineSymbol(
              SimpleLineSymbol.STYLE_SOLID,
              new Color([255, 0, 0, 0.5]),
            null
          map.enableSnapping({
            snapPointSymbol: symbol,
            tolerance: 20,
            snapKey: keys.ALT
          myEditor.startup();
          query(".dijit.dijitReset.dijitInline.dijitLeft.dijitComboButton", myEditor.domNode).forEach(function(node){
            domStyle.set(node, "display", "none");
    </script>
  </head>
  <body class="claro">
    <div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;">
      <div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'">
        Edit Hydrography
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width: 300px;overflow:hidden;">
        <div id="templateDiv"></div>
        <div id="editorDiv"></div>
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" id="map" data-dojo-props="region:'center'"></div>
    </div>
  </body>
</html>
Kushendra,
<!DOCTYPE html>
<html>
  <head>
    <style>
      #map{
        padding:0;
      #header{
        font-size: 1.1em;
        padding-left: 1em;
        padding-top:4px;
        color:#660000;
      .templatePicker {
        border: none;
    </style>
    <script>
      var map;
      require([
        "esri/map",
        "esri/Color",
        "esri/config",
        "dojo/domReady!"
      ], function(
        parser.parse();
          zoom: 14,
          slider: false
          outFields: ['*']
          outFields: ['*']
            grouping: true,
            rows: "auto",
            columns: 3
          }, "templateDiv");
          var settings = {
            map: map,
            layerInfos: layers,
            createOptions: {
            toolbarOptions: {
            15,
            null
            tolerance: 20,
            snapKey: keys.ALT
          myEditor.startup();
    </script>
  </head>
        Edit Hydrography
      </div>
      </div>
    </div>
  </body>
</html>
KushendraShah1
Thanks for the sending the sample Robert. It works great with the simple toolbar sample. When I tried to put on my template which is using default editing widget,  I still see the toolbar visible. I am using editor widget without having  template picker and I don't know if it is causing an issue. All I embed was this piece of code including the module ( "dojo/_base/array",
"dojo/parser",
"dojo/keys",
"dojo/query",
"dojo/dom-style")  : query(".dijit.dijitReset.dijitInline.dijitLeft.dijitComboButton", myEditor.domNode).forEach(function(node){
I tried using this code on esri default editor widget sample ArcGIS API for JavaScript Sandbox ; it seems it is not working.
Kushendra,
  I am confused as that sample does not even show the toolbar.
KushendraShah1
Robert, I activated the toolbar inside the settings variable and checked to see if works since I am using the default editor widget sample for my template.
var settings = {
map: map,
layerInfos: featureLayerInfos,
toolbarOptions: {
It displays the toolbar and when I tried using modules and put the snippet you sent in the sample doesn't work for this template (default editor widget). I don't know the issue behind since both the editor widget template and simple editor toolbar are similar to me as I am fairly new to the arcgis javascript world
Kushendra,
  OK you must of had something off in you code then. Here is a working example for the editor widget:
<!DOCTYPE html>
<html>
  <head>
    <title>Default Editor</title>
    <style>
      html, body {
        height: 100%;
        width: 100%;
        margin: 0;
      body {
        background-color: #fff;
        overflow: hidden;
        font-family: Helvetica, san-serif;
      #templatePickerPane {
        width: 225px;
        overflow: hidden;
      #panelHeader {
        background-color: #92A661;
        border-bottom: solid 1px #92A860;
        color: #FFF;
        font-size: 18px;
        height: 24px;
        line-height: 22px;
        margin: 0;
        overflow: hidden;
        padding: 10px 10px 10px 10px;
      #map {
        margin-right: 5px;
        padding: 0;
      .esriEditor .templatePicker {
        padding-bottom: 5px;
        padding-top: 5px;
        height: 500px;
        border-radius: 0px 0px 4px 4px;
        border: solid 1px #92A661;
      .dj_ie .infowindow .window .top .right .user .content, .dj_ie .simpleInfoWindow .content {
        position: relative;
    </style>
    <script>
      var map;
      require([
        "esri/config",
        "esri/map",
        "esri/SnappingManager",
        "esri/toolbars/draw",
        "dojo/keys",
        "dojo/parser",
        "dojo/_base/array",
        "dojo/query",
        "dojo/dom-style",
        "dojo/domReady!"
      ], function (
        esriConfig, Map, SnappingManager, Editor, FeatureLayer, GeometryService,
        Draw, keys, parser, arrayUtils, i18n, query, domStyle
        parser.parse();
        //snapping is enabled for this sample - change the tooltip to reflect this
        i18n.toolbars.draw.start += "<br/>Press <b>CTRL</b> to enable snapping";
        i18n.toolbars.draw.addPoint += "<br/>Press <b>CTRL</b> to enable snapping";
        //This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to
        //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
        //for details on setting up a proxy page.
          basemap: "topo",
          center: [-77.036, 38.891],
          zoom: 16
        map.on("layers-add-result", initEditing);
        var operationsPointLayer = new FeatureLayer("https://services5.arcgis.com/lVkj5PBOw7tRmIPU/arcgis/rest/services/HSEC/FeatureServer/0", {
          outFields: ["*"]
        var operationsLineLayer = new FeatureLayer("https://services5.arcgis.com/lVkj5PBOw7tRmIPU/arcgis/rest/services/HSEC/FeatureServer/1",{
          outFields: ["*"]
        var operationsPolygonLayer = new FeatureLayer("https://services5.arcgis.com/lVkj5PBOw7tRmIPU/arcgis/rest/services/HSEC/FeatureServer/3", {
          outFields: ["*"]
        map.addLayers([
          operationsPointLayer, operationsPolygonLayer, operationsLineLayer
        map.infoWindow.resize(400, 300);
        function initEditing (event) {
          var featureLayerInfos = arrayUtils.map(event.layers, function (layer) {
            return {
              "featureLayer": layer.layer
          var settings = {
            map: map,
            toolbarOptions: {
          var params = {
            settings: settings
          var editorWidget = new Editor(params, 'editorDiv');
          editorWidget.startup();
          query(".dijit.dijitReset.dijitInline.dijitLeft.dijitComboButton", editorWidget.domNode).forEach(function(node){
          //snapping defaults to Cmd key in Mac & Ctrl in PC.
          //specify "snapKey" option only if you want a different key combination for snapping
          map.enableSnapping();
    </script>
  </head>
    <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width:100%; height:100%;">
      <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" id="templatePickerPane" data-dojo-props="region:'left'">
        <div id="panelHeader">
          Default Editor
        </div>
        <div style="padding:10px;" id="editorDiv">
        </div>
      </div>
    </div>
  </body>
</html>
KushendraShah1
Robert, I was able to hide all the tools but the separator line. Is there way I can get rid of toolbar separator?  I use css code to hide this separator line but as soon as I stop and start my editor window it continue display. Looking forward to your help.
here is the CSS:
#dijit_ToolbarSeparator_0.dijitToolbarSeparator.dijitInline {
display: none;
KellyHutchins
Esri Notable Contributor
You can add the following javascript at line 144 of Robert's sample to hide the separator.
     query(".dijitToolbarSeparator").style("display", "none");
Alternatively if you only want undo/redo capability then you may want to turn off the editor toolbar and just add in the undo/redo capability. Here's a sample that shows how this works with graphics:
Graphics with undo redo | ArcGIS API for JavaScript 3.18
KushendraShah1
Thanks for the javascript line Kelly. Appreciated.
KushendraShah1
It works great Robert! There was the small error on my code.  I really appreciated your time looking into this and solving my problem. Thank you.
Happy Thanksgiving!
Kush
