How to hide the login dialog box when I use token
1006
01-05-2023 07:26 PM
rendtime
I use "IdentityManager. generateToken" to generate tokens,
and "IdentityManager. registerToken" to register tokens.
There may be some errors during the access, such as unauthorized and user errors.
At this time, the login dialog will pop up.
However, I never want it to pop up. I just print the error information on the console
JoelBennett
MVP Regular Contributor
The solution described in this post may be what you're looking for.
JoelBennett
rendtime
Can work, although not perfect, thank you
