How to hide "Esri World Geocoder" in the search widght with Arcgis-js-api 3.x
2732
08-22-2019 01:32 AM
zxz
Egge-Jan_Pollé
Hi z xz‌,
Pass in empty source array to clear the default ArcGIS Online World Geocoding service:
sources: []
See this example, showing the defaults ArcGIS Online World Geocoding service:Search multiple sources | ArcGIS API for JavaScript 3.29
No you can modify the code (e.g. in CodePen) to modify the search to remove this default service:
      var search = new Search({
        enableButtonMode: true, //this enables the search widget to display as a single button
        enableLabel: false,
        enableInfoWindow: true,
        showInfoWindowOnSelect: false,
        map: map,
        //passing in empty source array to clear the default ArcGIS Online World Geocoding service
        sources: []
      }, "search");
Does this work for you?
Cheers,
Egge-Jan
Egge-Jan_Pollé
Hi z xz‌,
sources: []
        enableLabel: false,
        map: map,
        sources: []
      }, "search");
Cheers,
Egge-Jan
zxz
It works,thank you!
Egge-Jan_Pollé
Hi z xz‌,
If your issue has been solved, you may mark my answer as correct. In this way it will be clear to others - who may have the same question - that your question has been answered correctly.
Cheers,
Egge-Jan
