How to get lat long of an offsetted graphic layer?
1683
03-09-2012 01:02 PM
KaitoSoto
Say I have a shape of a point:
var shape = new esri.geometry.Point(somex, somey, new esri.SpatialReference({wkid:4326}));
var simpleMarkerSymbol = new esri.symbol.SomeSymbol(-Insert Attributes Here-).setOffset(5,5);
var graphic = new esri.Graphic(shape, simpleMarkerSymbol);
I need a way to be able to get the lat long of the graphic post-application of the offset. How do I do this? Examples appreciated.
KaitoSoto
Is this really impossible to do?
StephenLead
Honored Contributor
I haven't tested this, but you could try:
var long = graphic.geometry.x;
var lat = graphic.geometry.y;
I'm assuming that the offset only applies to the marker symbol, not to the graphic itself, so the geometry should be unchanged.
derekswingley1
Steve is right�?? use the graphic geometry's x and y to get your coordinates. The offset you're applying affects the symbol, not the actual geometry.
KaitoSoto
The issue is I want to draw a polyline from the shape to the offset point. If I can't get the lat long of the offsetted point, it won't work unless I am able to draw a shape that is always offset from the shape to the offset point. Though since working in lat longs, I'm not sure what the computation for the lat long would be if i wanted to draw a point say 5pixels up and 5 pixels left from a shape unless there is an easier way to do that.
StephenLead
Honored Contributor
Hi Kaito,
Take a look at toMap(screenPoint) and toScreen(mapPoint) which may help - they convert coordinates between page and map coordinates.
You may be able to obtain the map coordinate of the graphic, convert it to page units, offset it, and convert that back to map units.
Steve
