How to generate a calcite radio button group from a view layerList
2686
05-15-2022 02:05 PM
GregoryBologna
I am trying to relocate a layerList added to an expand widget to a Calcite action bar, but I think that I'm going about it wrong. I am iterating my loaded layerList and building a calcite radio button group that is then added to the action bar. Is this the correct approach? Seems like there's a faster way.
Here's a code excerpt of my layerList.
var layerListExpand = new Expand({
    content: (layerList = new LayerList({
        view: view,
        listItemCreatedFunction: function listItemCreatedFunction(event) {
            var item = event.item;
            var key = item.title.toUpperCase().replace(/ /g, '');
            if (item.layer.type === 'group' || item.layer.type === 'tile') {
                if (key === 'AERIALS') {
                    watchUtils.whenFalse(item.layer, 'visible', function (newVal) {
                        layerListFormat(item);
                    watchUtils.whenTrue(item, 'visible', function (newVal) {
    view: view,
    autoCollapse: true,
    expanded: false,
    expandTooltip: 'Map Layers',
    group: 'top-right',
    mode: 'floating',
Build radio button group from loaded layerList
item.layer.layers.forEach(function (item) {
    if (item.type === 'imagery-tile') {
        let block = document.createElement('calcite-block');
        block.setAttribute('heading', item.title);
        block.setAttribute('collapsible', '');
        let notice = document.createElement('calcite-notice');
        notice.setAttribute('active', '');
        let div = document.createElement('div');
        div.setAttribute('slot', 'message');
        let rbg = document.createElement('calcite-radio-button-group');
        rbg.setAttribute('name', 'basic-group');
        rbg.setAttribute('layout', 'vertical');
        let label = document.createElement('calcite-label');
        rbg.setAttribute('layout', 'inline');
        rbg.innerHTML = item.title;
        let rb = document.createElement('calcite-radio-button');
        label.appendChild(rb);
        rbg.appendChild(label);
        document.querySelector(`[data-panel-id=layers-container]`).appendChild(rbg);
Tags (1)
AdrianaPaese
Hi Gregory
This is how you create the container:
It is a property of the layerList
var layerList = new LayerList({
                        view: view,
                        selectionEnabled: true,
                        listItemCreatedFunction: defineLayerListActions,
                        container: "layers-container"
and then you add the container to your calcite-panel
                <calcite-panel width-scale="m" height-scale="m" data-panel-id="layers" hidden>
                    <div id="layers-container"></div>
                </calcite-panel>
AdrianaPaese
You can associate a calcite-panel to your calcite-action
and then place a div with the layerList container inside the calcite-panel
You will be able to access the layerList from there..
GregoryBologna
I don't have a layerList container because I'm building the layerList with listItemCreatedFunction.
let layerList = new LayerList({
	view: view,
 yields
In html
  <calcite-action-bar slot="action-bar">
	<calcite-action data-action-id="aerials" text="aerials"></calcite-action>
  </calcite-action-bar>
  <calcite-panel heading="aerials" height-scale="l" data-panel-id="aerials">
	<div id="aerials-container"></div>
  </calcite-panel>
I'm stuck getting the layerList added to the div.
let ac = document.getElementById('aerials-container');
//ac.appendChild(layerList);
AdrianaPaese
Hi Gregory
                        view: view,
                </calcite-panel>
AdrianaPaese
In your code it would be:
let layerList = new LayerList ({
view: view,
container: "aerials-container",
listItemCreatedFunction: function ....
GregoryBologna
I first applied what you showed me to the print widget and a few other widgets and it all worked great, but I was still having trouble with the layerList.
      let print = new Print({
        view: view,
        printServiceUrl: printServiceUrl,
        container: 'print-block'
It was not until your next reply that I realized the issue was due to the layerList loading before the container I put it in was available (I create the calcite-blocks in code behind when an action bar item is clicked. I moved the layerList to the click event of the action bar item where it then loads and works great. Thank you!
