How to format numeric attribute values in an infoWindow
1578
11-10-2010 12:42 PM
StephenLead
Honored Contributor
Is it possible to format attribute values in an infoWindow?
For example, see the sample at http://help.arcgis.com/EN/webapi/javascript/arcgis/demos/query/query_hover.html
The infoWindow template uses population density values from attribute values in a variable:
infoTemplate.setContent("<b>2000 Population: </b>${POP2000}<br/>"
                             + "<b>2000 Population per Sq. Mi.: </b>${POP00_SQMI}<br/>"
                             + "<b>2007 Population: </b>${POP2007}<br/>"
                             + "<b>2007 Population per Sq. Mi.: </b>${POP07_SQMI}");
Is it possible to apply formatting to these values, eg so the POP07_SQMI value is rounded to zero decimal places?
Steve
BradCochran
not sure if there is a fancy way to do it, but the boring javascript way is to just use Math.round
for example,
Math.round(2232.43534) //returns 2232
so you could do something like,
var popRounded = Math.round(POP07_SQMI);
StephenLead
Honored Contributor
Hi Brad,
Thanks for the reply. As far as I can see, the problem is that the value of the attribute isn't evaluated at the time that the infoTemplate is created (so there's nothing to round yet). The code is setting up a template that is read at the point at which the graphic object is created.
Put another way - I can't see how to put the Math.round directive in the code above, and have it run as JavaScript, rather than being quoted as text. I'm not a JS expert.......
Any help would be appreciated.
Cheers,
Steve
KellyHutchins
Esri Notable Contributor
This question comes up frequently so I added a new sample to the ArcGIS Resource Center this morning showing how to format the contents of an info window.  The sample formats string values but could easily be modified to apply numeric or date formatting.
http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples/fl_infowindow.html
FYI: We are making some changes at 2.2 that will simplify this process.
StephenLead
Honored Contributor
Thanks again Kelly, I'll give it a go.
It would definitely be nice to be able to include the formatting directions in the infoWindow template, rather than having to listen for the click event.
