How to fixed the size of the map?
1003
12-14-2021 03:21 AM
altair
Hi all I hope you all doing well, I have a problem regarding of sizes of map, in the first load the size is good and correct and when the data is load the size of the map is changes, please check the image below
first load
after the data finish the load
const [getUserData] = useLazyQuery(ME);
const [getLocations] = useLazyQuery(GET_ALL_Star.);
const mapDiv = useRef(style);
let orgId = null;
useEffect(() => {
location();
const fetchData = () => {
getUserData()
.then((result) => {
return result.data;
.then(({ me }) => {
orgId = organization.id;
return getLocations({
variables: {
paging: {},
.then((result) => {
return result.data;
.then(({ location}) => {
displayLocation(location)
const location = () => {
if (mapDiv.current) {
esriConfig.apiKey = process.env.ARCGIS_API_KEY;
const map = new Map({
basemap: 'arcgis-light-gray',
const view = new MapView({
center: [123.5504, 12.3574], // Longitude, latitude
container: mapDiv.current,
map: map,
zoom: 2, // Zoom level
autoResize:true
view
.when((r) => {})
.then(() => {
mapDiv.current = view;
fetchData();
const displayLocation = (locations) => {
locations.data = locations.data.filter((l) =>{
return l.geoCode && l.orgId == orgId;
const centerLocation = CalculateCenter(locations);
const zoom = CalculateZoomLevel(mapDiv, locations);
mapDiv.current.center = [centerLocation.longitude, centerLocation.latitude];
mapDiv.current.zoom = [zoom];
mapDiv.current.autoResize= false;
locations.data.map((location) => {
const point = new Graphic({
geometry: {
latitude: location.geoCode.latitude,
longitude: location.geoCode.longitude,
type: 'point',
symbol: StarPin,
mapDiv.current.graphics.add(point);
return <div className="mapDiv" ref={mapDiv}></div>;
CourtneyMenikheim
Looking at the two images, you can see star pins in areas of the map that aren't visible on the first map. When you run the following code snippet, you are telling the map to resize.
Without seeing everything in CalculateZoomLevel, it's hard to identify specifics, but I suspect the method is getting the extent of all the features and using that in part of the calculation.
Courtney Menikheim
