How to embed Legend on to the map. Javascript 3.27
3176
02-25-2019 05:42 AM
MatthewBarr6
I am currently scripting out my first webmap with the Javascript API.  So far I am able to add my basemap, feature layers, zoom tool, home button, and search bar.
I am getting stuck on the legend.  This is the only example I was able to find for the 3.27 API.
Legend | ArcGIS API for JavaScript 3.27
The problem is that I don't want a content pane on the right side, I would like to be able to embed my legend at the bottom left of the map and then alter the way to it looks from there.
Is there any examples online that I am missing that show how to do this?  I am using the 3.27 Javascript API.
RobertScheitlin__GISP
Matthew,
   Here is a sample for that:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>FeatureLayer On Demand</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.27/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.27/esri/css/esri.css">
    <style>
      html, body, #mapDiv {
        padding:0;
        margin:0;
        height:100%;
      #legendDiv {
        position:absolute !important;
        right:20px;
        top:10px;
        z-Index:999;
        width: 200px;
        height: 200px;
        background-color: white;
        padding:8px;
    </style>
    <script src="https://js.arcgis.com/3.27/"></script>
    <script>
      var map;
      require([
        "esri/map", "esri/InfoTemplate", "esri/layers/FeatureLayer", "esri/dijit/Legend", "dojo/_base/array",
        "dojo/parser", "dojo/domReady!"
      ], function(
        Map, InfoTemplate, FeatureLayer, Legend, arrayUtils,
        parser
        parser.parse();
        map = new Map("mapDiv", {
          basemap: "national-geographic",
          center: [-96.541, 38.34],
          zoom: 6
        map.on("load", initOperationalLayer);
        function initOperationalLayer() {
          var infoTemplate = new InfoTemplate("${state_name}", "Population (2000):  ${pop2000:NumberFormat}");
          var featureLayer = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/2",{
            mode: FeatureLayer.MODE_ONDEMAND,
            outFields: ["*"],
            infoTemplate: infoTemplate
          map.addLayers([featureLayer]);
          map.infoWindow.resize(155,75);
          map.on("layers-add-result", function (evt) {
            var layerInfo = arrayUtils.map(evt.layers, function (layer, index) {
              return {layer:layer.layer, title:layer.layer.name};
            if (layerInfo.length > 0) {
              var legendDijit = new Legend({
                map: map,
                layerInfos: layerInfo
              }, "legendDiv");
              legendDijit.startup();
    </script>
  </head>
  <body class="claro">
    <div id="mapDiv">
      <div id="legendDiv"></div>
    </div>
  </body>
</html>
Matthew,
<!DOCTYPE html>
<html>
  <head>
    <style>
        padding:0;
        margin:0;
        height:100%;
      #legendDiv {
        right:20px;
        top:10px;
        z-Index:999;
        width: 200px;
        height: 200px;
        padding:8px;
    </style>
    <script>
      var map;
      require([
      ], function(
        parser
        parser.parse();
          zoom: 6
            outFields: ["*"],
                map: map,
              }, "legendDiv");
    </script>
  </head>
    <div id="mapDiv">
    </div>
  </body>
</html>
MatthewBarr6
Thank you this is exactly what I needed!  I really appreciate your time and effort!
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
MatthewBarr6
Just did, thanks again! Have a great day!
