Is there an alternative to using the Draw toolbar? Will the draw toolbar be in 4.0 final?
The plan is to have a rudimentary version of Draw in 4.0 final.
Thank you. And what about Editor? Will there also be some form of that as well?
Rudimentary means an access to the toolbar like it is now?
Not sure if you're referring to 3.15 or 4.0 beta 3 when you say "now", but the plan is to have basic draw capabilities like drawing a line, point, polygon. It won't look the same as 3.15.
Hi Kristian!
Thanks for your answer!
We are using the 3.15 Api by now and i have programmed a tool which allows the user
to select what Geometry he wants to draw, the Color of the Outlines/Filling, Linewidth/style etc.
and i want to make sure if it will work further on.
Then this should work in 4.0, maybe with some changes i think.
Regards, Miriam
@Kristian Ekenes
what is the latest plan? I cannot find Draw even in version 4.1 final.
