How to display a hosted feature layer within Javascript API?
1253
06-24-2022 07:39 AM
MatthewMinick
We are trying to integrate ArcGIS with our existing ASP.NET Blazor application.
For that, I have published a feature layer within ArcGIS Online and consuming it as a rest service within the Javascript API mapping application.
But the problem we are facing is, the layer is displayed on the map, whenever its sharing setting is set as "Public/Everyone", but the layer is not displayed on the map if I change the setting to "Organization".
Can somebody please help me figure out why this is happening?
KenBuja
MVP Esteemed Contributor
If you haven't shared it publicly, then you have to use authentication to gain access to them. Here's an example
<html>
<head>
  <meta charset="utf-8" />
  <meta name="viewport"
        content="initial-scale=1,maximum-scale=1,user-scalable=no" />
  <title>
    Intro to FeatureLayer | Sample | ArcGIS API for JavaScript 4.24
  </title>
  <link rel="stylesheet"
        href="https://js.arcgis.com/4.24/esri/themes/light/main.css" />
  <script src="https://js.arcgis.com/4.24/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require(["esri/Map", "esri/views/MapView", "esri/layers/FeatureLayer", "esri/identity/OAuthInfo", "esri/identity/IdentityManager",], (
      Map,
      MapView,
      FeatureLayer,
      OAuthInfo,
      identityManager
      const portalUrl = 'your portal url';
      const info = new OAuthInfo({
        appId: "your appId", //*** Your Client ID value goes here ***//
        popup: false // inline redirects don't require any additional app configuration
      identityManager.registerOAuthInfos([info]);
      // send users to arcgis.com to login
      identityManager.getCredential(portalUrl);
      identityManager.checkSignInStatus(portalUrl).then(function () {
        const map = new Map({
          basemap: "hybrid"
        const view = new MapView({
          container: "viewDiv",
          map: map,
          extent: {
            // autocasts as new Extent()
            xmin: -160.27,
            ymin: 18.89,
            xmax: -154.79,
            ymax: 22.26,
            spatialReference: 4326
        const featureLayer = new FeatureLayer({
          url: "your url"
        map.add(featureLayer);
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
