How to delete a polygon?
1142
08-25-2013 07:31 PM
JasonBarles
I have this code so far and it is able to execute the alert("hello"), but never gets into the function for applyEdits to delete a polygon. What am I doing wrong?
   dojo.connect(map.graphics, "onClick", function(evt) {
     dojo.stopEvent(evt);
       if (evt.ctrlKey === true) {  //delete feature if ctrl key is depressed
        alert("hello");
         map.graphics.applyEdits(null, null, [evt.graphic], function() {
          alert("delete");
            var operation = new esri.dijit.editing.Delete({
              featureLayer: map.graphics,
              deletedGraphics: [evt.graphic]
JohnGravois
applyEdits() is a featureLayer method.  if you just want to delete a graphic, just call map.graphics.remove(evt.graphic) instead
JohnGravois
