How to deactivate the popup
1130
09-24-2011 10:38 AM
SwenWaschk
I've been searching and reading a lot of forum entries but I can't seem to figure out how to deactivate the popup when i start adding graphics. I've changed this sample so the identify is activated once a button in the html is clicked. And I want to deactivate it with a click on another button.
Identify features on a map - sample
How do I do that?
StephenLead
Honored Contributor
Sven,
You can do this by assigning the dojo.connect call to a variable, which allows you to switch it off later.
//to switch it on
var clickListener = dojo.connect(map,"onClick",executeIdentifyTask);
// to switch it off
dojo.disconnect(clickListener);
Steve
SwenWaschk
Hi Steve,
Thanks, I'm going to try it and I'll get back to you.
Swen
