How to customize the FeatureTable
6830
9
03-18-2021 09:36 AM
ShaningYu
Honored Contributor
I use ESRI's FeatureTable widget (4.x)
https://developers.arcgis.com/javascript/latest/sample-code/widgets-featuretable-map/
I want to customize it somehow.  On the Grid's top-right the ... represents the "Options".  How can it be set off?
Thanks.
Tags (1)
KenBuja
MVP Esteemed Contributor
Adding this to the CSS will remove the button
.esri-feature-table__menu .esri-button-menu {
  display: none;
KenBuja
  display: none;
LefterisKoumis
Hello @KenBuja . Where can see all available css properties for the feature table or all esri widgets? Thank you.
KenBuja
The widget pages should have a link to the css information in the See Also section
You can also right click on the widget and use the Inspect option to get more information about all of its CSS.
LefterisKoumis
Thank you @KenBuja . I am surprised that there is no css to change background color of rows. Only when you hover over it or select it.
ShaningYu
Honored Contributor
Thanks for your response.  In my app, I created a dynamic table as shown below:
contx.myTable = new mv.esriModules.FeatureTable({
layer: contx.myFeatureLayer,
visibleElements: { selectionColumn: false },
fieldConfigs: _fieldsConfig,
container: document.getElementById("tableDiv")
How can the style be added dynamically?  Thanks.
KenBuja
If you don't want to add it to the CSS style section in your html, you can add it dynamically several different ways: https://developer.mozilla.org/en-US/docs/Web/API/CSS_Object_Model/Using_dynamic_styling_information
ShaningYu
Honored Contributor
KenBuja:  Resolved.  Thanks a lot!
MarioEstevez
ShaningYu,
Could you share your solution? I have a similar problem. I'm trying to change the background color of a cell based on the value on another cell.
Thanks!
KenBuja
Glad to help. Don't forget to click the Accept as Solution button or post how you resolved it.
