How to correct displacement between ArcGISDynamicMapServiceLayer and Bing Map
4099
10
01-23-2013 12:47 AM
ValeryOsipov
Hello, could you help me to combine to layers?
Background is esri.virtualearth.VETiledLayer.MAP_STYLE_AERIAL
Red lines are from esri.layers.ArcGISDynamicMapServiceLayer(""http://maps.rosreestr.ru/ArcGIS/rest/services/CadastreNew/Cadastre/MapServer"");
Backround shifts approximattely 4.6 meters to north and 2.7 meters to east
[ATTACH=CONFIG]20990[/ATTACH]
ValeryOsipov
veTileLayer.tileInfo.Origin.X -= 5; // shift Bing layer for 5 meters to left
JohnGravois
since both layers are published in web mercator (wkid:102100), its too late to correct their current alignment.  you would have to make changes to the published service (probably with regard to the datum transformation) in order to acheive higher accuracy.
what was the original projection of the data you are using for boundaries in your own service?
what transformation method was used when reprojecting to Web Mercator?
where (city/country) is your screenshot located?
ValeryOsipov
We work with local coordinate system, called SK-32. I heard, that it was build on Bessel ellipsoid, but i dont know what it means.
rosreestr.ru is goverment service.
Hope that is the information, you asked for.
Russia, Bryansk
JohnGravois
well... its definitely too late to try and correct misalignment after both services are published in Web Mercator (WKID:102100).  in order to troubleshoot it will be necessary to identify which datum transformation was applied when reprojecting out of the local coordinate system and see if there is a more appropriate choice.
ValeryOsipov
So, only map service owner can correct it, it's not possible to do it with javascript API, did i understand you correctly?
JohnGravois
correct.  Our API does not give you the ability to manipulate the alignment of two services published in an identical coordinate system.
ValeryOsipov
Solved problem by changing VETiledLayer's origin.
JohnGravois
awesome fix!
i dont see any properties or methods in our API for VETiledLayer related to origin.  would you be able to explain in a little more detail how you made the change?
ValeryOsipov
JohnGravois
very cool.  thanks for taking the time to explain in detail.
