How to convert an array of (X,Y) point to (Lat,Long)
1802
07-24-2019 02:05 PM
MuralidharMoka
I have an array of projected (X,Y)  points, which I am trying to convert to array of (lat,long).
I wrote the following method which will take  a single (X, Y ) and  give me ( Lat, Long). This works.
But I do not know how to use this to process my (X,Y) array. This should be simple, but could not get it.
function getLatLong(X,Y){
        return  (new Promise(function (resolve, reject) {
            require(["esri/tasks/GeometryService",
                    "esri/geometry/Point",
                    "esri/tasks/ProjectParameters",
                    "esri/SpatialReference"],
                function (GeometryService, Point, ProjectParameters, SpatialReference) {
                    var XCoord = parseInt(X, 10);
                    var YCoord = parseInt(Y, 10);
                    var inSR = new SpatialReference({wkid: 2274});
                    var outSR = new SpatialReference({wkid: 4326});
                    var gsvc = new GeometryService("https://mapviewtest.memphistn.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
                    var inputpoint = new Point(XCoord, YCoord, inSR);
                    var prjParams = new ProjectParameters();
                    prjParams.geometries = [inputpoint];
                    prjParams.outSR = outSR;
                     gsvc.project(prjParams);
                     gsvc.on("project-complete",function(outputpoint){
                        resolve(outputpoint);
                    gsvc.on("error",function(err){
                        reject(err);
        }));//promise
Thanks
Muralidhar Moka
KellyHutchins
Esri Notable Contributor
ProjectParameters.geometries accepts an array of input geometries to project. So instead of providing one point as you do in your code above
You can loop through all your x,y coordinates create input points and set them all to the prjParams.geometries.
