How to check if graphic is a circle?
4897
8
09-18-2014 10:30 AM
VygintasCesnauskas
I am looking for a way to check whether a shape clicked on by a user is a circle [esri/geometry/Circle]. I've tried using evt.graphic.geometry.type but it is coming back as 'polygon'. What's the best way to check it?
JonathanUihlein
Unfortunately, it appears the object returned by the Draw widget is not a true Circle object, but a Polygon object. Therefore, the circle specific properties are not available. Bummer!
We can still work with this though.
Since you know the currently selected draw tool is the circle tool, you can save this as an attribute on the graphic itself when the graphic is created.
Something like:
graphic.attributes.shape = "circle";
circle-amd | API Reference | ArcGIS API for JavaScript
TimWitt2
I don't think there is a way to see it besides polygon. How are your shapes created? Maybe in your creation you could add an attribute that defines what kind of shape it is and you could later pull that?
SteveCole
Honored Contributor
Circles have properties in the API such as center, radius, etc. Maybe you can test the graphic for the presence of a valid value? If it has one, then it's a circle. Kind of like feature sniffing to test for a particular browser.
Otherwise, a crude but probably not foolproof alternative would be test for type=polygon and geometry.width = geometry.height (pseudo code, obviously).
JonathanUihlein
This is the best solution.
SteveCole
Honored Contributor
To follow up, I tested points, lines, and polygons. "graphic.geometry.radius" returns undefined for those types but it will return a value for circles.
VygintasCesnauskas
Hi Steve, I'm getting undefined "graphic.geometry.radius" on all shapes, including circles. Circle was drawn using drawToolbar.activate(Draw["CIRCLE"]);
JonathanUihlein
Something like:
VygintasCesnauskas
Johathan, I went with your idea and it worked. I set the "shape" attribute for the graphic before adding it to the map:
var graphic = new Graphic(evt.geometry, symbol);
graphic.setAttributes({ "shape": evt.target._geometryType });
Then I use it to identify the shape once user clicks on it:
if (evt.graphic.attributes.shape == "circle") {
     editToolbar.activate(Edit.SCALE, evt.graphic);
Thanks for your help.
SteveCole
Honored Contributor
How about something like creating a new temporary circle graphic like this:
  var point = new Point([-117.15,32.71]);
var circleGeometry = new Circle(point,{
"radius": 1
And then, at the appropriate time, try to update that circle variable with your graphic that may/may not be a circle:
var isCircle = false;
try {
     circleGeometry = evt.graphic;
     isCircle = true;
} catch(err) {
    isCircle = false;
My theory is that, if it is a circle, you will be able to update the previously declared graphic variable. If it isn't, it will throw an error.
