how to change the coordinate-conversion button color
2386
8
09-03-2019 10:48 AM
RichardRhone
I want to change the color of the coordinate-conversion button only. have tried
.esri-widget--button
background-color:blue;
but this changes all widgets
RobertScheitlin__GISP
Ah. So you want this then:
.esri-coordinate-conversion .esri-widget--button {
  background-color: blue;
Richard,
Use this rule then:
.esri-coordinate-conversion__select-row {
RichardRhone
Thanks for the reply, Robert. However, this changes the select. I want to change the select button as seen below
Richard,
Hmm... That is exactly what it does for me.
RichardRhone
That's the result i got too. However, I actually want to change the button circled below to blue
RichardRhone
Thanks Robert!   This resolves the issue.
Another question...... is it possible to disable the button as well
Richard,
Quite a bit more to that assuming you want to be able to re-enable it in code too.
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1, maximum-scale=1,user-scalable=no"
    <title>CoordinateConversion widget - 4.12</title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.12/esri/themes/light/main.css"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
        overflow: hidden;
      .btndisabled {
        pointer-events: none;
    </style>
    <script src="https://js.arcgis.com/4.12/"></script>
    <script>
      require([
        "esri/views/MapView",
        "esri/widgets/CoordinateConversion",
        "esri/Map",
        "dojo/query",
        "dojo/dom-class",
        "esri/core/watchUtils"
      ], function(MapView, CoordinateConversion, Map, query, domClass, watchUtils) {
        var map = new Map({
          basemap: "topo"
        var view = new MapView({
          container: "viewDiv",
          map: map,
          center: [-117.049, 34.485],
          zoom: 12
        var ccWidget = new CoordinateConversion({
          view: view
        view.ui.add(ccWidget, "bottom-left");
        watchUtils.watch(ccWidget.viewModel, 'state', function(evt){
          var button = query(".esri-coordinate-conversion .esri-widget--button")[0];
          console.info(button);
          domClass.add(button, "btndisabled");
    </script>
  </head>
  <body class="calcite">
    <div id="viewDiv"></div>
  </body>
</html>
RichardRhone
Thanks Robert!
Had to update the style part as the button was still enabled on some browsers
<style>
        button:disabled,
        button[disabled] {
            border: 1px solid #999999;
            background-color: transparent;
            color: transparent;
</style>
This achieves exactly what i was looking for. Basically, i used the widget to custom convert. However, I dont want users to have an option to change this
