How to change the center point to move smoothly
1269
04-20-2022 04:49 AM
Lazy
view.on("click", (e) => {
                                let { latitude, longitude } = e.mapPoint;
                                let point = {
                                    type: "point",
                                    longitude,
                                    latitude,
                                let pointGraphic = new Graphic({
                                    geometry: point,
                                    symbol: this.pointSymbol,
                                pointLayer.removeAll();
                                pointLayer.add(pointGraphic);
                                view.center = [longitude, latitude];
JeffreyWilkerson
I think you want to mess with the MapView goTo GoToOptions2D options, as in this example:
<meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>Popup actions | Sample | ArcGIS API for JavaScript 4.22</title>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.22/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.22/"></script>
    <script>
      require([
        "esri/Map",
        "esri/layers/FeatureLayer",
        "esri/layers/GraphicsLayer",
        "esri/views/MapView",
        "esri/Graphic"
      ], (Map, FeatureLayer, GraphicsLayer, MapView, Graphic) => {
        // Create the Map
        const map = new Map({
          basemap: "gray-vector"
        // Create the MapView
        const view = new MapView({
          container: "viewDiv",
          map: map,
          center: [-117.08, 34.1],
          zoom: 11
        const template = {
          // autocasts as new PopupTemplate()
          title: "Trail run",
          content: "{name}"
        const featureLayer = new FeatureLayer({
          url: "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/TrailRuns/FeatureServer/0",
          popupTemplate: template
        map.add(featureLayer);
        let gLayer = new GraphicsLayer({});
        map.add(gLayer);
        view.when(() => {
            let point = {
              type: "point",
              longitude,
              latitude
              geometry: point,
            gLayer.removeAll();
            gLayer.add(pointGraphic);
            let goToOpts = {
              animate: true,
              duration: 2000,
              easing: "ease" //linear, ease, ease-in, ease-out, or ease-in-out
            view.goTo({
              center: [longitude, latitude]
            }, goToOpts);
            //view.center = [longitude, latitude];
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
