How to change layer name using map components
1289
03-28-2025 11:48 AM
JaredPilbeam2
  <arcgis-map zoom="13" center="-88.1, 41.5">
    <arcgis-zoom position="top-left"></arcgis-zoom>
    <arcgis-swipe swipe-position="32"></arcgis-swipe>
    <arcgis-expand position="top-right">
      <arcgis-layer-list
      label="1862 Imagery"
      visibility="checkbox"
      ></arcgis-layer-list>
    </arcgis-expand>
  </arcgis-map>
I thought I would be able to change the layer name from AerialBW1862 by using a label property in the Layer List component, but it has no effect. I've tried most other relevant-sounding properties, but still no effect. Here is a sample
2 Solutions
ReneRubalcava
Esri Frequent Contributor
The layer name comes from the "layer.title", so you can add your own title when you create the layer.
SteveCole
Honored Contributor
Was just coming to post that. Example mod to your code:
      const image1862 = new ImageryLayer({
        url: "https://gis.willcountyillinois.com/image/rest/services/Orthoimagery/AerialBW1862/ImageServer",
        title: "Aerial Photo",
        maxScale: 3000,
ReneRubalcava
SteveCole
Honored Contributor
        maxScale: 3000,
