How to change a basemap to map in EPSG:3826 format
1053
12-20-2023 11:14 PM
AbramhumHsu
Hi:
I am a newbie to ArcGIS javascript. I meet a problem about develop a map application.
After test and try, I found there must be set basemap in map class first, like following:
  const map = new Map({
                    basemap: "dark-gray" // basemap styles service
But since the project I need to develop now, the basemap is not in gallery, so how to build a basemap first via
tileLayer, and then include this data into basemap, such as following:
                    basemap: "my EPSG:3826 map" // basemap styles service
How to make that, any instructions is highly appreciated, thanks a lot.
JoelBennett
MVP Regular Contributor
It appears the fourth item listed under the "Creating a Basemap" section of the Basemap module documentation is what you're looking for.
JoelBennett
