How to center map after extent is declared - JavaScript API
7449
6
11-27-2012 05:11 AM
DavidLetz
Hello, I have a basemap zoomed into Harris County, Texas with the following code:
        function init() {
            var initialExtent = new esri.geometry.Extent({
                "xmin": -10679597.979853602,
                "ymin": 3465380.1480138917,
                "xmax": -10557604.482710624,
                "ymax": 3504286.5954109943,
                "spatialReference": {
                    "wkid": 102100
            map = new esri.Map("map", { extent: initialExtent });
            //Base Map Layer
            var baseMapLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
            map.addLayer(baseMapLayer);
However, the map is not exactly centered where I want it. I know there is a method named centerAt(point) that will do this, but whenever i try using it by supplying the lat/lon of my center point in that method, I end up on the other side of the world, or no map at all--I suspect it defaults to (0,0) off of the west coast of Africa.
            //TRY TO CENTER THE MAP USING THE LAT/LON
           // var mygeo = esri.geometry.geographicToWebMercator(new esri.geometry.Point(29.818008, -95.423178, new esri.SpatialReference({ wkid: 102100 })));
            var mylat = 29.818008;
            var mylong = -95.423178;
            var CenPoint = new esri.geometry.Point({ "x": mylat, "y": mylong, " spatialReference": { " wkid": 102100 } });
                extent: initialExtent,
                infoWindow: popup
            map.centerAt(CenPoint);
Can yiou tell me what i am doing wrong/
Many thanks for your help.
derekswingley1
When using geographicToWebMercator, the point you pass in needs a geographic spatial reference. In your example, you're using web mercator as the spatial reference.
Try this:
var CenPoint = new esri.geometry.Point({ "x": mylat, "y": mylong, " spatialReference": { " wkid": 4326 } });
var mercator = esri.geometry.geographicToWebMercator(CenPoint);
map.centerAt(mercator);
DavidLetz
Thanks for the reply!!
I tried your code, and at least I am not in the Atlantic Ocean anymore, but the map did not "center" with the centering code in place. Please see below. I had to put the center reference in the map constructor in order to return the map. do you see any obvious erros on my part?
var mylat = 29.452752;
var mylong = -95.424705;
  centerAt: (mercator), infoWindow: popup
TracySchloss
Honored Contributor
I've had better luck modifying the xmin,xmax of the initial extent.  When using the ESRI tiled base maps, it's not exact; you're always going to be tied to whatever scale is the nearest to the extent you specify.
DavidLetz
What is the most expedient way to change the extent? Using Firebug?
KenMorefield
I like to use this old ESRI sample to help me when trying to set the initial extent in my apps... It works pretty well...
Sample
Ken
DavidLetz
Sample
Ken
That is a really cool tool, thanks!!!
