How to call a querytask.execute in a event
1701
06-13-2014 07:15 AM
YinghongLi
My map needs to be updated every 15 minutes. I need to query to get new data time from the update. So i put a query function in "update-end" event. However the display function is never called. please help. Thanks
system info: ArcGIS Server 10.2.1; Javascript API 3.9
var l;
            if (layer.type == 'dynamic')
                l = new esri.layers.ArcGISDynamicMapServiceLayer(layer.url, layer.options);
                l.on("update-end", function (evt)
                    refreshcount++;
                    var timequery = new query();
                    alert("fewsquerytask==" + config.fewsQueryTaskService);
                    var queryTask = new QueryTask(config.fewsQueryTaskService);
                    timequery.returnGeometry = false;
                    timequery.outFields = ["PACKET_DATE_TIME"];
                    timequery.where = "PACKET_DATE_TIME is not null";
                    queryTask.execute(querytime, showTime);
                    function showTime(listfeatures)
                        alter("inside showTime");
                        var feature = listfeatures.features[0];
                        var value = feature.attributes["PACKET_DATE_TIME"];
                        alert("packet value==" + value);
                        dom.byId("packettime").innerHTML = "Refresh:  "+refreshcount+"  Packet Time:  " + value;
MarcusTownsend
May or may not work as expected but Thought I would point you in a possible right direction. you should be able to use a the  set interval function in Javascript to do what your trying to do.
  var refreshevent = setInterval(function (evt)
                  refreshcount++;
},900000);
YinghongLi
thanks.  I would give it a try.
the error was caused by a miss spelled variable name in queryTask.execute(querytime, showTime);  querytime should be timequery as it is defined in the code above.
JonathanUihlein
I would recommend using Deferreds and Promises over a native timer.
