Is there a function to getLayerDefinitions (similar to setLayerDefinitions) from web?
2606
6
06-16-2014 12:57 PM
CindyLu
Is there a function in Javascript APi layer.getLayerDefinitions from a web page map layers? I need to get this information using Javascript API. Or work around?
Thank you very much for any help.
Cindy
ManishkumarPatel
Hi Cindy,
I created a jsfiddle for you to refer.
http://jsfiddle.net/patelmanya/7Vgv7/
Click the Get layer Definition button to get the layer defintion for the layer added to the map.
Hope this helps.
Regards,
Manish
OwenEarley
Hi Cindy,
You can get this directly from a map service REST endpoint, for example:
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/la...
To access this JSON data in your JS code, use an esri.Request:
[HTML]<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Map Layers - JSON</title>
    <script src="http://js.arcgis.com/3.9/"></script>
    <script>
        require([
            "esri/request"
        ], function(esriRequest) {
            var layerUrl = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/la...";
            var layersRequest = esriRequest({
            url: layerUrl,
            content: { f: "json" },
            handleAs: "json",
            callbackParamName: "callback"
            layersRequest.then(
            function(response) {
              console.log("Success: ", response.layers);
              // process map service layers
            }, function(error) {
              console.log("Error: ", error.message);
    </script>
  </head>
  <body>
    <p>See the console output for map service layers</p>
  </body>
</html>[/HTML]
Hope this helps.
Owen
www.spatialxp.com.au
ManishkumarPatel
Hi Cindy,
You can try to use the below code to get the layer definition if it exists.
map.getLayer(map.layerIds[1]).layerDefinitions
or
map.getLayer("layerId").layerDefinitions
If  there is no layerDefinitions then the lenght will be 0.
Hope this helps.
Regards,
Manish
CindyLu
Hi Manish,
Thank you for your response. I tried layer.layerDefinitions, I got none.
I also want to mension that in the service, there is no layer definition. But I set the layer definition in Javascript code early. Then I want to get this layer definition for print.
dojo.forEach(map.layerIds, function(layer, i1){
  var ml = map.getLayer(layer);
  switch (ml.declaredClass) {
   case "esri.layers.ArcGISDynamicMapServiceLayer":
    var s = dojo.forEach(ml.layerInfos, function(sublayer, i2){
     if (dojo.indexOf(ml.visibleLayers, sublayer.id.toString()) !== -1) {
      alert(sublayer.name);
      alert(sublayer.id);
      alert(sublayer.layerDefinitions);
      visiblelayers[sublayer.name] = true;
      layerQuery[sublayer.name] = sublayer.layerDefinitions;
     else {
      visiblelayers[sublayer.name] = false;
But sublayer.layerDefinitions gives Null.
Thank you very much for your help.
Cindy
ManishkumarPatel
Hi Cindy,
Hope this helps.
Regards,
Manish
CindyLu
Thanks. I got it (even though it is not so easy when I have more than one layer services, and each layer service has sublayers).
Cindy
CindyLu
Hi Owen,
Your method may work, even though I have not try your method yet.
Cindy
