How to Calculate a centerpoint between different lines
1653
07-10-2018 07:19 AM
Pa_Lotus
How to Calculate a centerpoint between different lines as in image,
lines can be multiple and uneven structures
Any help greatly appreciated
Thank you
ReneRubalcava
Esri Frequent Contributor
This might help.
geom-engine-center-multi-lines
You can get the extent of each line, use the GeometryEngine to union the lines and then get the center of that unioned results extent.
ReneRubalcava
This might help.
