How to avoid tabbing on the popup
4663
01-26-2015 01:31 PM
BhavinSanghani
I am using InfoTemplate class in my application to show popup on the map. Let's say popup is open on the map. Now, if I try to navigate using tab key then cursor stops at Zoom To link.
If I want to avoid tabbing on this popup then how can I do that? e.g if you open following example in the browser and navigate using tab key then it will show cursor on Zoom To link when the control comes there. May be I need to set tabIndex="-1" on that link, but not sure how can I do that.
Formatter Function
ChrisSergent
According to the W3C you can set a tabIndex for the following:
Modulo platform conventions, it is suggested that for the following elements, the tabindex focus flag be set:
If this is your only link on the page, you could use the a element and write:
document.getElementByTagName("a").tabIndex = -1;
to skip it.
If that does not work, you could try getting element by class name which in this case is actionList, so it would be:
document.getElementsByClassName("actionList").tabIndex = -1;
There may be a different way to write this if you are using AMD, but I am not sure.
Worst case scenario, you could host the JavaScript API locally and name then manually add tabIndex = -1.
