How to add time slider for feature services
3209
6
01-31-2022 02:04 AM
pragati224
Hi Developers,
I am working on a point feature that has some datewise values. ineed to add it on time slider but unable to add. I followed the api refernce and sample codes but failed to fetch my data on time slider. the service is given below for which I am looking to add time slider.
Layer: Tree (ID:0) (arcgis.com)
Please help me to add my data on time slider.
SzuNyiapTang
Hi @pragati224
You might need to modify the Feature Service to have it time enabled.
Time-aware layers—ArcMap | Documentation (arcgis.com)
Cheers,
Tang
Cheers,
Tang
pragati224
The Feature Service is allready time enabled
SzuNyiapTang
Hi @pragati224 ,
Based on the feature service url given, I could not find any Time Info properties.
If the layer is Time Enabled, it should have Time Info properties.
Example:
Layer: Amount by Time (ID:0) (arcgis.com)
You may refer to the link in my previous comment to enable the time for the layer.
Cheers,
Tang
pragati224
I have updated the layer.and added it in 2d viewr but unable to add it in 3D. can you guide me how to add time slider on 3d.
https://services8.arcgis.com/Dxp0iiM83fijnVoI/ArcGIS/rest/services/Tree_D/FeatureServer/0
SzuNyiapTang
Hi @pragati224
Right now, there isn't any out-of-the-box timeslider for 3D application. You need to develop custom application like Undral shown.
Cheers,
Tang
UndralBatsukh
There is no difference between 2D and 3D TimeSlider. The same settings for the timeslider will work in 3D. I tried your service with timeSlider in 3D and the time slider is set up correctly. However, I could not figure out the time interval for your service.
 const layer = new FeatureLayer({
          url: "https://services8.arcgis.com/Dxp0iiM83fijnVoI/ArcGIS/rest/services/Tree_D/FeatureServer/0"
        const map = new Map({
          basemap: "gray-vector",
          layers: [layer]
        const view = new SceneView({
          map: map,
          container: "viewDiv",
          zoom: 18,
          center: [-79.4554618, 43.643389]
        // time slider widget initialization
        const timeSlider = new TimeSlider({
          container: "timeSlider",
          view: view,
          loop: true,
          mode: "instant"
        view.whenLayerView(layer).then((lv) => {
          timeSlider.fullTimeExtent =
            layer.timeInfo.fullTimeExtent;
          timeSlider.stops = {
            interval: {
              unit: "months",
              value: 3
