How to add shapefile without ArcGIS Online?
10655
8
01-22-2015 02:36 AM
StephenLam
Refering to this sample, I can do the things as expected. However, my ArcGIS Server and client PC cannot go to the internet, so can I setup the same thing in my intranet environment or can I just simply enable it in my ArcGIS manager? Thanks.
PaulCrickard
Use Leaflet.js map with leaflet.shapefile at calvinmetcalf/leaflet.shapefile · GitHub  it requires shapefile JS. Then you create a map as in the code below. In the zip I have 4 shapefiles with points and polygons. And you can use ESRI's leaflet plugin for their other stuff if you want. I am over the ESRI JavaScript API - I hate DOJO. It's like they love huge things like Flex and Silverlight and now DOJO for all the fancy widgets. Pretty over functional.
var m = L.map('map').setView([ 35.10418, -106.62987],8);
var watercolor = L.tileLayer('http://{s}.tile.stamen.com/watercolor/{z}/{x}/{y}.jpg',{attribution:'Map tiles by <a href="http://stamen.com">Stamen Design</a>, <a href="http://creativecommons.org/licenses/by/3.0">CC BY 3.0</a> &mdash; Map data &copy; <a href="http://openstreetmap.org">OpenStreetMap</a> contributors, <a href="http://creativecommons.org/licenses/by-sa/2.0/">CC-BY-SA</a>'}).addTo(m);
var shpfile = new L.Shapefile('apsschools.zip',{onEachFeature:function(feature, layer) {
    if (feature.properties) {
  layer.bindPopup(Object.keys(feature.properties).map(function(k){
  return k + ": " + feature.properties ;
  }).join("<br />"),{maxHeight:200});
         shpfile.addTo(m);
         shpfile.once("load", function(){
          console.log("finished loading shapefile");
JeffJacobson
You might be able to use this library:
mbostock/shapefile · GitHub
StephenLam
Thanks for your reply! Is this written in Node.js? I am not sure if I can setup the Node.js in my servers, but is there any other library, server object extension or sample to do the same thing also?
TimWitt2
Stephen,
you can always host the javascript API locally.
See the last paragraph here: Get the ArcGIS API for JavaScript | Guide | ArcGIS API for JavaScript
Hope this helps!
Tim
JeffJacobson
I didn't notice it was designed for Node.js.
There are other JavaScript libraries for shapefiles on GitHub, though.
Based on its documentation it looks like shapefile-js is designed to work in a browser.
PaulCrickard
         shpfile.addTo(m);
StephenLam
Thanks Paul, It works! Can this API convert the geometry based on my coordinate system of shape file?
I also don't like DOJO as it is huge size and slow performance....
PaulCrickard
My shapefile is in state plane and it converted automatically. If you want to read it back in the original projection, use something like proj4js.
BaizuraNapiah
hey paul, thanks for the codes, it works like a charm
but how to change the outline of the shapefile? like how to customize it to another color and change it from watercolor to a better outline
hope you can help, thanks
