how to add custom TileLayer
1487
10-31-2019 11:29 PM
yanli
I want  to  add  the  custom Tiles ,which  is  created  by Arcgis with  catalog.
it  can get the tile image from server but i can't view  in map. my code like this.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Custom TileLayer - 4.12</title>
  <link rel="stylesheet" type="text/css" href="http://localhost/arcgis_js_v412_api/arcgis_js_api/library/4.12/esri/themes/light/main.css"/>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script src="http://localhost/arcgis_js_v412_api/arcgis_js_api/library/4.12/init.js"></script>
  <script>
    require([
      "esri/Map",
      "esri/config",
      "esri/request",
      "esri/Color",
      "esri/geometry/Extent",
      "esri/geometry/SpatialReference",
	  "esri/layers/support/TileInfo",
      "esri/views/MapView",
      "esri/widgets/LayerList",
      "esri/layers/BaseTileLayer",
      "dojo/domReady!"
    ], function(
      Map, esriConfig, esriRequest, Color,Extent, SpatialReference ,TileInfo,
      MapView, LayerList, BaseTileLayer
      // Custom tile layer class code
      // Create a subclass of BaseTileLayer
      let spatialReference = new SpatialReference({ wkid: 4550 });
	  let extent=new Extent({
					    xmin:273521.70494464,
						ymin:3302005.502287823,
						xmax:440043.09505535045,
						ymax:3379261.04,
						spatialReference:{wkid:4550}
                      let tileInfo = new TileInfo({
							dpi: 96,
							rows: 256,
							cols: 256,
							compressionQuality: 0,
							origin: {
							  x: -5123200,
							  y: 10002100
							spatialReference: {
							  wkid: 4550
							lods: [
								level: 0,
								levelValue: 0,
								resolution:264.5838625010584,
								scale: 1000000
								level: 1,
								levelValue: 1,
								resolution: 132.2919312505292,
								scale:  500000
								level: 2,
								levelValue: 2,
								resolution: 66.1459656252646,
								scale:   250000
								level: 3,
								levelValue: 3,
								resolution: 33.0729828126323,
								scale:   125000
								level: 4,
								levelValue: 4,
								resolution: 16.933367200067735,
								scale:   64000
      var TintLayer = BaseTileLayer.createSubclass({
        properties: {
          urlTemplate: null,
          tint: {
            value: null,
            type: Color
        tileInfo: tileInfo,
        spatialReference: spatialReference
        // generate the tile url for a given level, row and column
        getTileUrl: function(level, row, col) {
          return "http://192.168.20.244/TileCache/Layers/_alllayers/" +
									  "L" + dojostring.pad(level, 2, '0') + "/" +
									  "R" + dojostring.pad(row.toString(16), 8, '0') + "/" +
									  "C" + dojostring.pad(col.toString(16), 8, '0') + "." +
									  "png";
        // This method fetches tiles for the specified level and size.
        // Override this method to process the data returned from the server.
        fetchTile: function(level, row, col) {
          // call getTileUrl() method to construct the URL to tiles
          // for a given level, row and col provided by the LayerView
          var url = this.getTileUrl(level, row, col);
          // request for tiles based on the generated url
          // set allowImageDataAccess to true to allow
          // cross-domain access to create WebGL textures for 3D.
          return esriRequest(url, {
              responseType: "image",
              allowImageDataAccess: true
            .then(function(response) {
              // when esri request resolves successfully
              // get the image from the response
              var image = response.data;
              var width = this.tileInfo.size[0];
              var height = this.tileInfo.size[0];
              // create a canvas with 2D rendering context
              var canvas = document.createElement("canvas");
              var context = canvas.getContext("2d");
              canvas.width = width;
              canvas.height = height;
              // Draw the blended image onto the canvas.
              context.drawImage(image, 0, 0, width, height);
              return canvas;
            }.bind(this));
      // Start of JavaScript application
      // Add stamen url to the list of servers known to support CORS specification.
      var stamenTileLayer = new TintLayer({
        tint: new Color("#004FBB"),
        title: "test"
      // add the new instance of the custom tile layer the map
      var map = new Map({
        layers: [stamenTileLayer]
      // create a new scene view and add the map
      var view = new MapView({
        container: "viewDiv",
        map: map,
        center: [360788, 3309983],
        extent: extent
      // create a layer list widget
      var layerList = new LayerList({
        view: view,
      view.ui.add(layerList, "top-right");
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
My tile url formate:http://192.168.20.244/TileCache/Layers/_alllayers/L00/R00000061/C0000004f.png
what't the problem ,can you help me
Tags (1)
UndralBatsukh
Looks like you are missing  "dojo/string" in your test app.
