How to accumulate flow
2338
02-01-2016 08:08 AM
SaraAlian
I'm trying to find a way to accumulate some flow values along the stream network (from the inlet all the way down to the outlet across the stream catchments).. I'm working with NHDPlus V2 data ( streams and catchments) and GPS data points as my study points. All the data is in vector format. I read about ArcHydro and worked with the tool but it was confusing and not helpful. I'm wondering if you could help me finr the answer.
XanderBakker
Esri Esteemed Contributor
Copy of question: Flow accumulation with ArcHydro .
I assume that you are not trying to establish the flow accumulation in a web environment using the JavaScript API. In that case, you may want to remove this question and let people answer the similar question you posted in the Arc Hydro Place.
SaraAlian
Thank you for replying back to my message. I'll delete my question.
