how get lat/lng from basic search javascript? ref: https://developers.arcgis.com/javascript/jssamples/search_basic.html
4034
8
03-19-2016 09:56 PM
CloudingSoft
RobertScheitlin__GISP
Fabien,
Here is a sample for that:
<!DOCTYPE html>
<html dir="ltr">
<head>
   <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
   <title>ArcGIS API for JavaScript | Basic Search</title>
   <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/themes/calcite/dijit/calcite.css">
   <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/themes/calcite/esri/esri.css">
   <style>
      html,
      body,
      #map {
         height: 100%;
         width: 100%;
         margin: 0;
         padding: 0;
      #search {
         display: block;
         position: absolute;
         z-index: 2;
         top: 20px;
         left: 74px;
   </style>
   <script src="https://js.arcgis.com/3.16/"></script>
   <script>
      require([
        "esri/map",
        "esri/dijit/Search",
        "esri/geometry/webMercatorUtils",
        "dojo/domReady!"
      ], function (Map, Search, webMercatorUtils) {
         var map = new Map("map", {
            basemap: "gray",
            center: [-120.435, 46.159], // lon, lat
            zoom: 7
         var search = new Search({
            map: map
         }, "search");
         search.startup();
        search.on('select-result', function(result){
          console.info(result.result.feature.geometry);
          web = webMercatorUtils.webMercatorToGeographic(result.result.feature.geometry);
          console.info("Lat: " + web.y +", Lon: " + web.x);
   </script>
</head>
<body class="calcite">
   <div id="search"></div>
   <div id="map"></div>
</body>
</html>
Fabien,
<!DOCTYPE html>
<html dir="ltr">
<head>
   <style>
      html,
      body,
      #map {
         height: 100%;
         width: 100%;
         margin: 0;
         padding: 0;
      #search {
         display: block;
         position: absolute;
         z-index: 2;
         top: 20px;
         left: 74px;
   </style>
   <script>
      require([
        "esri/map",
        "dojo/domReady!"
            basemap: "gray",
            zoom: 7
            map: map
         }, "search");
         search.startup();
   </script>
</head>
</body>
</html>
CloudingSoft
Excelent!
how get more info for webMercatorUtils in API Javascript?
Fabien,
  Sure here is the link to the API doc for that:
esri/geometry/webMercatorUtils | API Reference | ArcGIS API for JavaScript
CloudingSoft
ok.
question:
$("#search_input").attr("value","Chile"); //update new data input OK
$(".searchSubmit").click(); // ERROR IN INPUT search_input; "Introduce un término de búsqueda."
i need update map, how do?
OR update map from lat/log with javascrips?
Fabien,
  Just do this (line 14 and 15):
            map: map
         }, "search");
         search.startup();
        search.set("value", "Chile");
        search.search();
CloudingSoft
ok, but I need an external function
function updateMap(){
     search.set("value", "Chile");  //here "search" is UNDEFINED
     search.search();
Fabien,
  Here is an updated sample:
<!DOCTYPE html>
<html dir="ltr">
<head>
  <style>
    html,
    body,
    #map {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    #search {
      display: block;
      position: absolute;
      z-index: 2;
      top: 20px;
      left: 74px;
    .btnClass {
      display: block;
      position: absolute;
      z-index: 2;
      top: 60px;
      left: 74px;
  </style>
  <script>
    var search, map;
    require([
        "esri/map",
        "dojo/on",
        "dijit/registry",
        "dojo/parser",
        "dijit/form/Button",
        "dojo/domReady!"
      ], function (Map, Search, webMercatorUtils, on, registry, parser) {
      parser.parse();
        basemap: "gray",
        zoom: 7
        map: map
      }, "search");
      search.startup();
      search.on('select-result', function (result) {
        console.info("Lat: " + web.y + ", Lon: " + web.x);
      function updateMap() {
        search.search();
      on(registry.byId('ButtonNode'), "click", updateMap);
  </script>
</head>
  <button id="ButtonNode" data-dojo-type="dijit/form/Button" class="btnClass">Search...</button>
</body>
</html>
CloudingSoft
very very good!
thank you very much!
