How do you programmatically retrieve public maps from a group in AGOL?
1801
12-23-2019 12:43 PM
SkylerKroll
Hello. I had asked a question a couple of weeks ago about retrieving map items from a group in AGOL. The example I was given worked, but I need to get public times within a group. How would I go about doing this? I know the group Id, but I'm not sure how to query said group to get the items. Thanks.
KellyHutchins
Esri Notable Contributor
You can use the queryItems method on PortalGroup to query for items in the group: PortalGroup | ArcGIS API for JavaScript 4.14
SkylerKroll
Okay. Thank you. I will give the documentation a look.
SkylerKroll
Hi, Kelly. I'm having trouble with how to structure the syntax to query the items and populate the carousel with the map thumbnails. Can you help me along? Am I missing something?
 <script type = "text/javascript">
  require([
    "esri/core/urlUtils",
    "esri/portal/Portal",
    "esri/portal/PortalGroup",
    "esri/identity/OAuthInfo",
    "esri/identity/IdentityManager",
    "esri/portal/PortalQueryParams"
  ], function (urlUtilsPortalPortalGroupOAuthInfoesriIdPortalQueryParams) {
    urlUtils.addProxyRule({
              urlPrefix: "https://www.arcgis.com",
              proxyUrl: "https://localhost/dotnet/proxy.ashx"
    displayItems();
    function displayItems() {
      var portalGroup = new PortalGroup({
        owner: "Rocket350",
        portalUrl: "https://rocket350.maps.arcgis.com"
        // Query the group items from portalGroup above
        portalGroup.queryItems().then(populateCarousel);
    function populateCarousel(items) {
      //var htmlFragment = "";
      index = 0;
      items.results.forEach(function (item) {
        index += 1;
        if (item.type == "Web Map") {
          console.log(item.type);
          console.log(item.thumbnailUrl);
          //Sconsole.log(item.thumbnailUrl);
          // htmlFragment +=
          //   '<div class="esri-item-container">' +
          //   (item.thumbnailUrl
          //     ? '<div class="esri-image" style="background-image:url(' +
          //     item.thumbnailUrl +
          //     ');"></div>'
          //     : '<div class="esri-image esri-null-image">Thumbnail not available</div>') +
          //   (item.title
          //     ? '<div class="esri-title">' + (item.title || "") + "</div>"
          //     : '<div class="esri-title esri-null-title">Title not available</div>') +
          //   "</div>";
          $('<div class="carousel-item"><img src="'item.thumbnailUrl+'" width="50%"></div>').appendTo('.carousel-inner')
          console.log(index);
        else {
      $('.carousel-item').first().addClass('active');
      $('.carousel-indicators > li').first().addClass('active');
      $('#mapCarousel').carousel();
</script>
