How do you get view.toGo working??!!
2654
03-02-2017 11:14 AM
brianbullas
I am performing a query on a featurelayer. The query is returning results (I can see results in the console.log), but when i try to view.toGo(returnedFeature) nothing happens. I have tried fixed Point, and a lot of other things, but nothing seems to work. I have set up a button that when you click it, it does the query.
I am using the 4.2 API
require([
                    "esri/Map",
                    "esri/views/SceneView",
                    "esri/views/MapView",
                    "esri/layers/FeatureLayer",
                    "esri/tasks/QueryTask",
                    "esri/tasks/support/Query",
                    "esri/geometry/Point",
                    "dojo/on",
                    "dojo/domReady!"
                function (
                    Map,
                    SceneView,
                    MapView,
                    FeatureLayer,
                    QueryTask,
                    Query,
                    Point,
                    on
                    var template = {
                        title: "{Description}",
                        content: "<p>Asset ID:<b>{AssetID}</b></p>" +
                            "<p>Asset Status:<b>{AssetStatus}</b></p>"
                    var url = "http://tga-app-sandbox.tauranga.govt.nz:6080/arcgis/rest/services/TreeApp/TreeCapture_AllMaintainenc...";
                    var featureLayer = new FeatureLayer({
                        url: url,
                        outFields: ["*"],
                        popupTemplate: template
                    var map = new Map({
                        basemap: "hybrid",
                        spacialReference: featureLayer.spacialReference
                    var view = new MapView({
                        container: "viewDiv",
                        map: map,
                        zoom: 16,
                        center: [176.2, -37.7],
                    on(dojo.query("#default"), "click", function () {
                        var params = new Query({
                            returnGeometry: true,
                            outFields: ["*"]
                        params.where = 'AssetID = 141971';
                        var qTask = new QueryTask({
                            url: url
                        qTask.execute(params)
                            .then(function (response) {
                                if (!response || !response.features) {
                                    console.log("Asset not found.");
                                    return;
                                console.log(response.features);
                                view.goTo(response.features[0], { zoom: 18 });
                                //view.goTo({
                                //    target: new Point({
                                //        x: response.features[0].geometry.x,
                                //        y: response.features[0].geometry.y,
                                //        spatialReference: response.features[0].geometry.spatialReference
                                //    }), zoom: 18
                            .otherwise(function (err) {
                                console.log(err);
                    map.add(featureLayer);
                    view.then(function () {
                            outFields: ["*"]
                        params.where = 'AssetID = 115576';
                            url: url
                                    return;
                                view.goTo(response.features, {zoom: 5});
                                console.log(err);
                    }, function(error){
                        console.log( error);
What am i doing wrong? Neither of my view.goTo functions work?!
ReneRubalcava
Esri Frequent Contributor
Tough to to tell, that service isn't public. You do have spatialReference misspelled in a few places though.
Also, if you are using a non-webmercator spatialReference, you can't use the basemap strings, you have to create an empty map.
RobertScheitlin__GISP
Brain,
    It looks like a scope issue to me. When you call qTask.execute the deferred response is in a different scope. Do you see an error in your browsers console that says goTo is not a function of undefined or null? If that is the case then this is where you would use dojo/_base/lang reguire and lang.htich to maintain your codes scope or you need to make your view a global var instead of a local one.
brianbullas
There are no errors in the console. Here is the output after i refresh the page, then click the button:
brianbullas
I also just tried setting view to a global variable, and it still doesn't work / no errors in console  😕
ReneRubalcava
brianbullas
I got it working by creating my own Basemap and removing all spatialReference's.
Cheers!
