How do I resolve the conflict of info Windows on multiple widgets?
9529
20
12-18-2014 07:52 AM
ChrisSergent
I have a geocode widget and the default editor widget. They both use infoWindows. When I do a search for an address, the goecode widget's infoWindow is retained. For example if I search for an address of 100 S Main and then I click on the editor widget, instead of the editor window displaying, the address that I just search for displays. The conflict is infoWindow. What do I need to do to my code to resolve this conflict?
Here are the two blocks of code for these widgets:
Editor-
// Starts initEditing after the feature layer(s) have been added
                map.on("layers-add-result", initEditing);
                // add imagery
                var tiled = new ArgGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                map.addLayer(tiled);
                // add operational layer
                var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", {
                    "opacity": 0.5
                map.addLayer(operationalLayer);
                // add point feature layer for editing
                var pointFeatureLayer = new FeatureLayer("http://maps.decaturil.gov/arcgis/rest/services/Test/FeatureServer/0", {
                    mode: FeatureLayer.MODE_ONDEMAND,
                    outFields: ["*"]
                map.addLayers([pointFeatureLayer]);
                // settings for the editor widget
                function initEditing(event) {
                    // sizes the edit window
                    map.infoWindow.resize(400, 300);
                    var featureLayerInfos = arrayUtils.map(event.layers, function (layer) {
                        return {
                            "featureLayer": layer.layer
                    var settings = {
                        map: map,
                        layerInfos: featureLayerInfos,
                        toolbarVisible: true,
                        enableUndoRedo: true,
                        maxUndoOperations: 20
                    var params = {
                        settings: settings
                    var editorWidget = new Editor(params, 'editorDiv');
                    editorWidget.startup();
                    var options = { snapKey: keys.copyKey };
                    map.enableSnapping(options);
Geocode -
// begin geocoder
                var geocoder = new Geocoder({
                    arcgisGeocoder: false,
                    geocoders: [{
                        url: "http://maps.decaturil.gov/arcgis/rest/services/Public/WebAddressLocator/GeocodeServer",
                        name: "Web Address Locator",
                        placeholder: "Find address",
                        outFields: "*"
                    map: map,
                    autoComplete: true,
                    zoomScale: 600
                }, dom.byId("search"));
                geocoder.startup();
                geocoder.on("select", showGeocodeLocation);
                function showGeocodeLocation(evt) {
                    map.graphics.clear();
                    var point = evt.result.feature.geometry;
                    var symbol = new SimpleMarkerSymbol()
                        .setStyle("square")
                        .setColor([255, 0, 0, 0.5]);
                    var graphic = new Graphic(point, symbol);
                    map.graphics.add(graphic);
                    map.infoWindow.setTitle("Search Result");
                    map.infoWindow.setContent(evt.result.name);
                    map.infoWindow.show(evt.result.feature.geometry);
                    map.infoWindow.on('hide', function () {
                        map.infoWindow.clear();
                // end geocoder
KellyHutchins
Esri Notable Contributor
Chris and William
The trick to getting the editor's attribute inspector to play nicely with all the other info windows is to destroy and re-create the editor. I know that sounds like a drastic solution but here's an example showing this in action. In the code below when the info window associated with the geocode result is closed we destroy and re-create the editor - note when running the sample you won't notice that the editor is destroyed but your info windows should work correctly.
Decatur GIS Editor Template
Chris - in your code you have a proxy setup, which is good, but you've also specified that alwaysUseProxy is true. This means that all requests are routed through the proxy which is (most likely) not what you want to happen. Is the proxy setup in your app to handle editing? If so you might want to modify your app to use a proxy rule instead that points to just the editable layer.
williamcarr
Chris, Could you email me a copy of the rest of your code so I can get a better look at it?
ChrisSergent
Here is the complete code. It looks like the map.infoWindow.setContent is the issue:
<!DOCTYPE html>
<html>
<head>
  <title>Decatur GIS Editor Template</title>
  <meta http-equiv="content-type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
  <link rel="stylesheet" href="http://js.arcgis.com/3.12/dijit/themes/soria/soria.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.12/esri/css/esri.css">
  <!-- jQuery Styles -->
  <link href="css/custom-theme/jquery-ui-1.10.3.custom.min.css" rel="stylesheet" type="text/css" />
  <style>
    html,
    body,
    #mapDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width:100%;
      overflow:hidden;
    #mailPane
                width:240px;
                position:absolute;
                right:0%;
                bottom:0%;
                background-color:White;
                border-color:Black;
                z-index:50;
            .soria  .dijitTitlePaneTitle {
                background: #fff;
                font-weight:600;
                border: none;
                border-bottom:solid 1px #29201A;
                border-top:solid 1px #29201A;
            .soria .dijitTitlePaneTitleHover
                background:#eee;
            .soria .dijitTitlePaneTitleActive
                background:#808775;
            .soria .dijitTitlePaneContentOuter
                border-right: none;
                border-bottom: none;
                border-left: none;
    #titlePane
                width:240px;
                position:absolute;
                left:30%;
                bottom:0%;
                border-color:Black;
                z-index:50;
                background: #fff;
                font-weight:600;
                border: none;
                background:#eee;
                background:#808775;
                border-right: none;
                border-left: none;
    #HomeButton {
      position: absolute;
      top: 95px;
      left: 20px;
      z-index: 50;
    #LocateButton {
      position: absolute;
      top: 140px;
      left: 20px;
      z-index: 50;
    #search {
      display:block;
      position:absolute;
      z-index:3;
      top:20px;
      left:75px;
    .esriScalebarLine, .esriScalebarMetricLine
        border-color:White;
    .esriScalebarLabel, .esriScalebarLineLabel,.esriScalebarSecondNumber, .esriScaleLabelDiv
        text-shadow:-1px -1px 0 #fff,
            1px -1px 0 #fff,
            -1px 1px 0 #fff,
            1px 1px 0 #fff;
    /* Printer CSS Begin */
    h3 {
      margin: 0 0 5px 0;
      border-bottom: 1px solid #444;
      padding: 0 0 5px 0;
      text-align: center;
    .shadow {
      -moz-box-shadow: 0 0 5px #888;
      -webkit-box-shadow: 0 0 5px #888;
    #feedback {
      background: #fff;
      border: 2px solid #666;
      border-radius: 5px;
      bottom: 20px;
      color: #666;
      font-family: arial;
      height: 300px;
      left: 20px;
      margin: 5px;
      padding: 10px;
      position: absolute;
      width: 300px;
      z-index: 40;
      visibility: hidden;
    #feedback a {
      /*border-bottom: 1px solid #888;*/
      color: #666;
      text-decoration: none;
    #feedback a:hover,
    #feedback a:active,
    #feedback a:visited {
      border: none;
      color: #666;
    #note {
      padding: 0 0 10px 0;
    #info,
    #information {
      padding: 10px 0 0 0;
    #printer {
      height: 20px;
      width: 20px;
      position: absolute;
      top: 240px;
      left: 20px;
      z-index: 50;
      padding: 5px 6px 5px 6px;
      background-color: #f9f8f8;
      border-radius: 5px;
      visibility: hidden;
    /* Printer CSS End */
    /* Editor CSS Begin */
    #editor
        height:20px;
        width:20px;
        position:absolute;
        top:285px;
        left:20px;
        z-index:50;
        padding: 5px 6px 6px 6px;
        background-color:#f9f8f8;
        border-radius:5px;
        visibility:hidden;
    /* Editor CSS End */
    /* Editor style begin */
    #templatePickerPane {
        width: 250px;
        height:260px;
        overflow: hidden;
        z-index:50;
        top:50%;
        right:0%;
        position:absolute;
    #panelHeader
        background-color: #92A661;
        border-bottom: solid 1px #92A860;
        color: #FFF;
        font-size: 18px;
        height: 50px;
        line-height: 22px;
        margin: 0;
        overflow: hidden;
        padding: 10px 10px 10px 10px;
    #editorDiv
        padding:10px;
        .esriEditor .templatePicker
        padding-bottom: 5px;
        padding-top: 5px;
        height: 120px;
        border-radius: 0px 0px 4px 4px;
        border: solid 1px #92A661;
        .dj_ie .infowindow .window .top .right .user .content, .dj_ie .simpleInfoWindow .content
        position: relative;
    /* Editor Style End */
    #closeEditor
        position:absolute;
        right:5%;
    #editor
        height:20px;
        width:20px;
        position:absolute;
        top:285px;
        left:20px;
        z-index:50;
        border-radius:5px;
        visibility:hidden;
    #showTools {
      height: 20px;
      width: 20px;
      position: absolute;
      top: 200px;
      left: 20px;
      z-index: 50;
      border-radius: 5px;
      visibility: visible;
    #hideTools {
      height: 20px;
      width: 20px;
      position: absolute;
      top: 200px;
      left: 20px;
      z-index: 50;
      border-radius: 5px;
      visibility: hidden;
  </style>
  <script src="http://js.arcgis.com/3.12/"></script>
  <!-- jQuery Library -->
  <script src="js/jquery-1.9.1.js" type="text/javascript"></script>
  <script src="js/jquery-ui-1.10.3.custom.min.js" type="text/javascript"></script>
  <!-- Enables jquery mouse events to work as touch events on mobile devices: https://github.com/copernicus365/jquery-ui-touch-punch/blob/master/jquery.ui.touch-punch.js -->
  <script src="js/jquery.ui.touch-punch.js" type="text/javascript"></script>
  <script>
      var map;
      var graphic;
      var currLocation;
      var watchId;
      var pt;
      var app = {};
      require(["esri/map", "esri/config",
              "esri/Color",
              "esri/dijit/editing/Editor",
              "esri/dijit/Geocoder",
              "esri/dijit/HomeButton",
              "esri/dijit/LocateButton",
              "esri/dijit/Measurement",
              "esri/dijit/OverviewMap",
              "esri/dijit/Scalebar",
              "esri/geometry/Extent",
              "esri/geometry/Point",
              "esri/geometry/screenUtils",
              "esri/graphic",
              "esri/layers/ArcGISTiledMapServiceLayer",
              "esri/layers/ArcGISDynamicMapServiceLayer",
              "esri/layers/FeatureLayer",
              "esri/layers/LayerDrawingOptions",
              "esri/renderers/SimpleRenderer",
              "esri/SnappingManager",
              "esri/sniff",
              "esri/SpatialReference",
              "esri/symbols/SimpleFillSymbol",
              "esri/symbols/SimpleLineSymbol",
              "esri/symbols/SimpleMarkerSymbol",
              "esri/tasks/GeometryService",
              "esri/tasks/PrintParameters",
              "esri/tasks/PrintTask",
              "esri/tasks/PrintTemplate",
              "esri/tasks/ProjectParameters",
              "esri/toolbars/draw",
              "dojo/dom",
              "dojo/keys",
              "dojo/on",
              "dojo/parser",
              "dojo/query",
              "dojo/_base/array",
              "dojo/_base/Color",
              "dojo/i18n!esri/nls/jsapi",
              "dojo/dnd/Moveable",
              "dijit/layout/BorderContainer",
              "dijit/layout/ContentPane",
              "dijit/TitlePane",
              "dijit/form/CheckBox",
              "dojo/domReady!"
            ], function (Map, esriConfig, Color, Editor, Geocoder,
                         HomeButton, LocateButton, Measurement, OverviewMap, Scalebar, Extent, Point, screenUtils, Graphic,
                         ArgGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer, FeatureLayer, LayerDrawingOptions, SimpleRenderer, SnappingManager, has,
                         SpatialReference, SimpleFillSymbol, SimpleLineSymbol, SimpleMarkerSymbol,
                         GeometryService, PrintParameters, PrintTask, PrintTemplate, ProjectParameters, Draw, dom, keys, on, parser, query, arrayUtils, Color, i18n, Moveable
                parser.parse();
                //snapping is enabled for this sample - change the tooltip to reflect this
                i18n.toolbars.draw.start += "<br/>Press <b>CTRL</b> to enable snapping";
                i18n.toolbars.draw.addPoint += "<br/>Press <b>CTRL</b> to enable snapping";
                /* The proxy comes before all references to web services */
                /* Files required for security are proxy.config, web.config and proxy.ashx
                - set security in Manager to Private, available to selected users and select Allow access to all users who are logged in
                (Roles are not required)
                The proxy section is defined on the ESRI sample. I have included it as
                part of the documentation that reads that the measuring will not work.
                I thought that might be important.
                // Proxy Definition Begin
                //identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
                //If this null or not available the project and lengths operation will not work.
                // Otherwise it will do a http post to the proxy.
                esriConfig.defaults.io.proxyUrl = "proxy.ashx";
                esriConfig.defaults.io.alwaysUseProxy = true;
                // Proxy Definition End
                // declare geometry service
                esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
                // set custom extent
                var initialExtent = new Extent({
                    "xmin": 777229.03,
                    "ymin": 1133467.92,
                    "xmax": 848340.14,
                    "ymax": 1185634.58,
                    "spatialReference": {
                        "wkid": 3435
                // create map and set slider style to small
                map = new Map("mapDiv", {
                    showAttribution: false,
                    sliderStyle: "small",
                    extent: initialExtent,
                    logo: false
                // add imagery
                    "opacity": 0.5
                    outFields: ["*"]
                        return {
                    var settings = {
                        map: map,
                    var params = {
                        settings: settings
                // Allow editor to move with mouse or finger
                jQuery(function () {
                    jQuery("#templatePickerPane").draggable({ containment: "window" });
                // Allow print widget to move with mouse or finger
                    jQuery("#feedback").draggable({ containment: "window" });
                // Hide editor
                on(dom.byId("closeEditor"), "click", function () {
                    document.getElementById("templatePickerPane").style.visibility = 'hidden';
                // Show Editor
                on(dom.byId("showEditorWidget"), "click", function () {
                    document.getElementById("templatePickerPane").style.visibility = 'visible';
                // begin print Task
                app.printUrl = "http://maps.decaturil.gov/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%2...";
                function createPrintTask(printTitle) {
                    var template = new PrintTemplate();
                    template.layout = document.getElementById("printLayoutId").value;
                    template.label = "Landscape (PDF)";
                    template.format = document.getElementById("printFormatId").value;
                    template.layoutOptions = {
                        legendLayers: [], // empty array means no legend
                        scalebarUnit: "Miles",
                        titleText: printTitle
                    var params = new PrintParameters();
                    params.map = map;
                    params.template = template;
                    var printTask = new PrintTask(app.printUrl);
                    var printObj = {
                        printTask: printTask,
                        params: params
                    return printObj;
                // end of print task
                // Activates printer
                on(dom.byId("btnPrintReady"), "click", function () {
                    document.getElementById("btnPrintReady").innerHTML = "Printing..."
                    document.getElementById("btnPrintReady").disabled = true;
                    var printObj = createPrintTask(document.getElementById("printTitleId").value);
                    var printTask = printObj.printTask;
                    printTask.execute(printObj.params, function (evt) {
                        document.getElementById("btnPrintReady").style.display = 'none';
                        document.getElementById("printResult").href = evt.url;
                        document.getElementById("printResult").style.display = 'block';
                        on(dom.byId("printResult"), "click", function () {
                            document.getElementById("btnPrintReady").innerHTML = "Print";
                            document.getElementById("btnPrintReady").style.display = 'block';
                            document.getElementById("btnPrintReady").disabled = false;
                            document.getElementById("printResult").style.display = 'none';
                    }, function (evt) {
                // Hides print widget
                on(dom.byId("closePrint"), "click", function () {
                    document.getElementById("feedback").style.visibility = 'hidden';
                // Shows tools
                on(dom.byId("showTools"), "click", function () {
                    document.getElementById("showToolsButton").style.visibility = 'hidden';
                    document.getElementById("hideToolsButton").style.visibility = 'visible';
                    document.getElementById("printer").style.visibility = 'visible';
                    document.getElementById("editor").style.visibility = 'visible';
                // Hide tools
                on(dom.byId("hideTools"), "click", function () {
                    document.getElementById("showToolsButton").style.visibility = 'visible';
                    document.getElementById("hideToolsButton").style.visibility = 'hidden';
                    document.getElementById("printer").style.visibility = 'hidden';
                    document.getElementById("editor").style.visibility = 'hidden';
                // Show print widget
                on(dom.byId("showPrintWidget"), "click", function () {
                    document.getElementById("feedback").style.visibility = 'visible';
                // begin geocoder
                    geocoders: [{
                        outFields: "*"
                    map: map,
                    autoComplete: true,
                    zoomScale: 600
                geocoder.startup();
                        .setStyle("square")
                    //map.infoWindow.setTitle("Search Result" + "<br /><hr>" + evt.result.name);
                // end geocoder
                // add home button to get full extent begin
                var home = new HomeButton({
                    map: map,
                    useTracking: false
                }, "HomeButton");
                home.startup();
                // add home button to get full extent end
                // add overview map begin
                var overviewMapDijit = new OverviewMap({
                    map: map,
                    visible: false
                overviewMapDijit.startup();
                // add overview end
                // scalebar begin
                var scalebar = new Scalebar({
                    map: map,
                    scalebarUnit: "dual"
                // scalebar end
                // start measurement tool - the current layer we are measuring is the operational layer
                var layerDrawingOptions = [];
                var layerDrawingOption = new LayerDrawingOptions();
                var sfs = new SimpleFillSymbol(
                                    "solid",
                                    new SimpleLineSymbol("solid", new Color([195, 176, 23]), 2),
                                    null
                layerDrawingOption.renderer = new SimpleRenderer(sfs);
                // change 1 to the layer index that you want to modify:
                layerDrawingOptions[1] = layerDrawingOption;
                //dojo.keys.copyKey maps to CTRL on windows and Cmd on Mac., but has wrong code for Chrome on Mac
                var snapManager = map.enableSnapping({
                    snapKey: has("mac") ? keys.META : keys.CTRL
                var layerInfos = [{
                    layer: operationalLayer
                snapManager.setLayerInfos(layerInfos);
                var measurement = new Measurement({
                    map: map
                }, dom.byId("measurementDiv"));
                measurement.startup();
                // end measurement tool
                // Begin geolocate button
                // add geolocate button to find the location of the current user
                map.on("load", function () {
                    geoLocate = new LocateButton({
                        map: map,
                        highlightLocation: true,
                        useTracking: true,
                        enableHighAccuracy: true
                    }, "LocateButton");
                    geoLocate.clearOnTrackingStop = true;
                    geoLocate.startup();
                    geoLocate.locate();
                // End geolocate button
  </script>
</head>
<body class="soria">
  <!-- Map begin -->
  <div id="mapDiv">
    <div id="HomeButton"></div>
    <div id="LocateButton"></div>
    <div id="showTools">
      <input type="image" id="showToolsButton" src="images/hammer.png" alt="Show Tools" title="Show Tools" />
    </div>
    <div id="hideTools">
      <input type="image" id="hideToolsButton" src="images/close.ico" alt="Hide Tools" title="Hide Tools" />
    </div>
    <div id="printer">
      <input type="image" id="showPrintWidget" src="images/print.ico" alt="Print" title="Print" />
    </div>
    <div id="editor">
        <input type="image" id="showEditorWidget" src="images/edit.ico" alt="Editor" title="Editor" />
    </div>
    <form id="frmPrint" action="" onsubmit="return false;">
      <div id="feedback">
        <h3>City of Decatur Print Service</h3>
        <div id="information">
          <div id="note">Note: Select the format that you would like to print your map from the dropdowns below.</div>
          <!-- used for the print dijit -->
          <label id="lblPrintTitle">Enter a print title</label>
          <br />
          <input type="text" id="printTitleId" name="printTitle" value="Street Light Inventory" />
          <br />
          <br />
          <select name="printLayout" id="printLayoutId">
            <option value="A3 Landscape">A3 Landscape</option>
            <option value="A3 Portrait">A3 Portrait</option>
            <option value="A4 Landscape">A4 Landscape</option>
            <option value="A4 Portrait">A4 Portrait</option>
            <option value="Letter ANSI A Landscape" selected>Letter ANSI A Landscape</option>
            <option value="Letter ANSI A Portrait">Letter ANSI A Portrait</option>
            <option value="Tabloid ANSI B Landscape">Tabloid ANSI B Landscape</option>
            <option value="Tabloid ANSI B Portrait">Tabloid ANSI B Portrait</option>
          </select>
          <select name="printFormat" id="printFormatId">
            <option value="pdf" selected>PDF</option>
            <option value="png32">PNG32</option>
            <option value="png8">PNG8</option>
            <option value="jpg">JPG</option>
            <option value="gif">GIF</option>
            <option value="eps">EPS</option>
            <option value="svg">SVG</option>
            <option value="svgz">SVGZ</option>
          </select>
          <br />
          <br />
          <button type="button" id="btnPrintReady">Print</button>
          <a href="#" id="printResult" target="_blank" style="display:none;">Get Printout</a>
          <div id="info">This print service is to be used for City business only.
            <input type="image" id="closePrint" src="images/close.ico" alt="Close" title="Close" />
          </div>
        </div>
      </div>
    </form>
    <div id="search"></div>
    <div id="titlePane" data-dojo-type="dijit/TitlePane" data-dojo-props="title:' Measurement', closeable:false,open:false">
        <div id="measurementDiv"></div>
        <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span>
    </div>
    <div id="mailPane" data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Ask For Assistance',closeable:false,open:false">
        <div id="send Mail">
            <p>Send mail to: We'll tell you later.</p>
        </div>
    </div>
  </div>
  <! -- Map End -->
  <div id="templatePickerPane">
        <div id="panelHeader">
          <p>Default Editor     <input type="image" id="closeEditor" src="images/close.ico" alt="Close Editor" title="Close Editor" /></p>
        </div>
        <div id="editorDiv">
        </div>
      </div>
</body>
</html>
williamcarr
Ironically enough, we are both battling the same concept at the same time. I'm attempting to toggle between info window and the attribute inspector. It looks like you are trying to get address information in the info window, or search results?
This thread ended up working(for the most part, I'm having trouble getting an array in my initSelectToolbar to work). Re: Overriding a feature's infoTemplate using map.infoWindow.setContent()  The JSFiddle at the end has a working example.
Good Luck
KellyHutchins
Chris and William
ChrisSergent
I added the proxy because I thought that I saw the measure widget required a proxy. I can set that to false. Thanks.
williamcarr
Kelly,
Using this example Edit fiddle - JSFiddle , I've set up a toggle to go between charts in infoWIndows to attribute inspector. For some reason it is claiming  my (evt) is undefined.  Is it an issue with having multiple layers in the attribute inspector?
Appreciate the help.
map.on("click",function()
    var option= registry.byId("selectfield");
  var optionValue = option.value;
        if (optionValue == "ON"){console.log("adfasdfasdf");
         beacon1.setInfoTemplate();
          initSelectToolbar();
  else {  beacon1.setInfoTemplate(popupTemplate1);}
  function initSelectToolbar(evt) {
          var asdf = evt.layers[0].layer;
          var selectQuery = new Query();
          map.on("click", function(evt) {
              var selectionQuery = new esri.tasks.Query();
        var tol = map.extent.getWidth()/map.width * 15;
        var x = evt.mapPoint.x;
        var y = evt.mapPoint.y;
        var queryExtent = new esri.geometry.Extent(x-tol,y-tol,x+tol,y+tol,evt.mapPoint.spatialReference);
        selectionQuery.geometry = queryExtent;
        asdf.selectFeatures(selectionQuery, FeatureLayer.SELECTION_NEW, function(features) {
               //store the current feature
                updateFeature = features[0]; console.log("adf");
                map.infoWindow.setTitle(features[0].getLayer().name); console.log("adf");
                map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint)); console.log("adf");
KellyHutchins
William,
I ran a quick test with your code and I don't see any errors in the console where evt is undefined. Which line is failing?
williamcarr
KellyHutchins
The JSFiddle you linked to does not have the line var asdf = evt.layers[0].layer in the code. Perhaps you sent the wrong fiddle?
