How do I resolve the conflict of info Windows on multiple widgets?
7264
20
12-18-2014 07:52 AM
ChrisSergent
I have a geocode widget and the default editor widget. They both use infoWindows. When I do a search for an address, the goecode widget's infoWindow is retained. For example if I search for an address of 100 S Main and then I click on the editor widget, instead of the editor window displaying, the address that I just search for displays. The conflict is infoWindow. What do I need to do to my code to resolve this conflict?
Here are the two blocks of code for these widgets:
Editor-
// Starts initEditing after the feature layer(s) have been added
                map.on("layers-add-result", initEditing);
                // add imagery
                var tiled = new ArgGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                map.addLayer(tiled);
                // add operational layer
                var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", {
                    "opacity": 0.5
                map.addLayer(operationalLayer);
                // add point feature layer for editing
                var pointFeatureLayer = new FeatureLayer("http://maps.decaturil.gov/arcgis/rest/services/Test/FeatureServer/0", {
                    mode: FeatureLayer.MODE_ONDEMAND,
                    outFields: ["*"]
                map.addLayers([pointFeatureLayer]);
                // settings for the editor widget
                function initEditing(event) {
                    // sizes the edit window
                    map.infoWindow.resize(400, 300);
                    var featureLayerInfos = arrayUtils.map(event.layers, function (layer) {
                        return {
                            "featureLayer": layer.layer
                    var settings = {
                        map: map,
                        layerInfos: featureLayerInfos,
                        toolbarVisible: true,
                        enableUndoRedo: true,
                        maxUndoOperations: 20
                    var params = {
                        settings: settings
                    var editorWidget = new Editor(params, 'editorDiv');
                    editorWidget.startup();
                    var options = { snapKey: keys.copyKey };
                    map.enableSnapping(options);
Geocode -
// begin geocoder
                var geocoder = new Geocoder({
                    arcgisGeocoder: false,
                    geocoders: [{
                        url: "http://maps.decaturil.gov/arcgis/rest/services/Public/WebAddressLocator/GeocodeServer",
                        name: "Web Address Locator",
                        placeholder: "Find address",
                        outFields: "*"
                    map: map,
                    autoComplete: true,
                    zoomScale: 600
                }, dom.byId("search"));
                geocoder.startup();
                geocoder.on("select", showGeocodeLocation);
                function showGeocodeLocation(evt) {
                    map.graphics.clear();
                    var point = evt.result.feature.geometry;
                    var symbol = new SimpleMarkerSymbol()
                        .setStyle("square")
                        .setColor([255, 0, 0, 0.5]);
                    var graphic = new Graphic(point, symbol);
                    map.graphics.add(graphic);
                    map.infoWindow.setTitle("Search Result");
                    map.infoWindow.setContent(evt.result.name);
                    map.infoWindow.show(evt.result.feature.geometry);
                    map.infoWindow.on('hide', function () {
                        map.infoWindow.clear();
                // end geocoder
ChrisSergent
Kelly,
Everything is working and ready to be rolled into my secure app.
Thanks again.
