How do I keep layers from being visible until I ask them to be?
3713
12
10-13-2010 07:23 AM
AlexGray
I have a webmap project I am working on that accesses mutilple layers within a couple different mapservices. I would like to learn how I can load the layers without them drawing. I've recently incorporated check boxes instead of links to turn each layer on and off. They work but in the reverse way I want them to.
I've not been able to figure out how to keep the layers from drawing until I select a checkbox..
Any ideas or help would be appreciated.. Thanks..
I've included a javascript code snippet from the page
  function init(){
    esri.hide(dojo.byId('loading'));
    dojo.connect(grid, "onRowClick", onRowClickHandler);
    esriConfig.defaults.map.sliderLabel = null;
  //Use the ImageParameters to set the visible layers in the map service during ArcGISDynamicMapServiceLayer construction.
        var imageParameters = new esri.layers.ImageParameters();
        imageParameters.layerIds = [1,2,3,4,5,6,7,8,9];
        imageParameters.layerOption = esri.layers.ImageParameters.LAYER_OPTION_HIDE;
        //can also be: LAYER_OPTION_EXCLUDE, LAYER_OPTION_HIDE, LAYER_OPTION_INCLUDE, LAYER_OPTION_SHOW
    var initialExtent = new esri.geometry.Extent({
     "xmin": -8746396.760545,
     "ymin": 4719239.393535,
     "xmax": -8683358.936355,
     "ymax": 4791953.233965,
     "spatialReference": {
      "wkid": 102113
    map = new esri.Map("map", {
     extent: initialExtent
    //Add the terrain service to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
    var initBasemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer", {
    map.addLayer(initBasemap);
    dojo.connect(map,'onLoad',function(theMap){
            var scalebar = new esri.dijit.Scalebar({
               map: map,
               scalebarUnit: "english"
              }, dojo.byId("scalebar"));
    var fireLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis.co.frederick.va.us/ArcGIS/rest/services/Fire_and_Rescue/Fire_and_Rescue/MapServer", {
     "imageParameters":imageParameters
    fireLayer.setVisibleLayers([3, 7]);
    legendLayers.push({
     layer: fireLayer,
     title: "Fire Rescue Layers"
    var patLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis.co.frederick.va.us/ArcGIS/rest/services/Planning/Planning_PAT/MapServer", {
     opacity: .6,
    patLayer.setVisibleLayers([3, 6, 1, 2, 4, 7, 8]);
    legendLayers.push({
     layer: patLayer,
     title: 'Planning Layers'
    dojo.connect(map, 'onLayersAddResult', function(results){
     var legend = new esri.dijit.Legend({
      map: map,
      layerInfos: legendLayers
     }, "legendDiv");
     legend.startup();
    navToolbar = new esri.toolbars.Navigation(map);
    dojo.connect(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler);
    createBasemapGallery();
    dojo.connect(dijit.byId('map'), 'resize', resizeMap);
    dojo.byId("toggle").innerHTML += "<span>Planning Layers:</span><br />";
    dojo.byId("toggle").innerHTML += "<input type='checkbox'id='1'onclick=\"JavaScript:toggleSubLayer('PAT',7)\">Urban Development Area</A><br />";
    dojo.byId("toggle").innerHTML += "<input type='checkbox'id='2'onclick=\"JavaScript:toggleSubLayer('PAT',1)\">Zoning</A><br />";
    dojo.byId("toggle").innerHTML += "<input type='checkbox'id='3'onclick=\"JavaScript:toggleSubLayer('PAT',2)\">Agricultural & Forestal Districts</A><br />";
    dojo.byId("toggle").innerHTML += "<input type='checkbox'id='4'onclick=\"JavaScript:toggleSubLayer('PAT',3)\">Buildings</A><br />";
    dojo.byId("toggle").innerHTML += "<input type='checkbox'id='5'onclick=\"JavaScript:toggleSubLayer('PAT',4)\">Future Land Use</A><br />";
    dojo.byId("toggle").innerHTML += "<input type='checkbox'id='6'onclick=\"JavaScript:toggleSubLayer('PAT',6)\">Sewer & Water Service Area</A><br />";
    dojo.byId("toggle").innerHTML += "<input type='checkbox'id='7'onclick=\"JavaScript:toggleSubLayer('PAT',8)\">County Boundary</A><br /><br />";
    dojo.byId("toggle").innerHTML += "<span>Service Layers:</span><br />";
    dojo.byId("toggle").innerHTML += "<input type='checkbox'id='8'onclick=\"JavaScript:toggleSubLayer('FireRescue',3)\">Fire Stations</A><br />";
    dojo.byId("toggle").innerHTML += "<input type='checkbox'id='9'onclick=\"JavaScript:toggleSubLayer('FireRescue',7)\">Hydrants</A><br />";
    map.addLayers([fireLayer, patLayer]);
  function toggleSubLayer(layerId, subLayerId) {
   var layer = map.getLayer(layerId);
    if(layer && layer.visibleLayers) {
   var visibleLayers = layer.visibleLayers;
   var layerIndex = dojo.indexOf(visibleLayers, subLayerId);
    if(layerIndex === -1) {
     visibleLayers.push(subLayerId);
    } else {
     visibleLayers.splice(layerIndex, 1);
  visibleLayers = (visibleLayers.length > 0) ? visibleLayers : [-1];
  layer.setVisibleLayers(visibleLayers);
Here is the 'body' code for the page..
 <body class="claro" >
  <div class="tundra" id="navToolbar" dojoType="dijit.Toolbar" style="width: 100%;">
    <div dojoType="dijit.form.Button" id="zoomin" iconClass="zoominIcon" onClick="navToolbar.activate(esri.toolbars.Navigation.ZOOM_IN); selected=true; ">Zoom In</div>
    <div dojoType="dijit.form.Button" id="zoomout" iconClass="zoomoutIcon" onClick="navToolbar.activate(esri.toolbars.Navigation.ZOOM_OUT);">Zoom Out</div>
    <div dojoType="dijit.form.Button" id="zoomfullext" iconClass="zoomfullextIcon" onClick="navToolbar.zoomToStartExtent();">Full Extent</div>
    <div dojoType="dijit.form.Button" id="zoomprev" iconClass="zoomprevIcon" onClick="navToolbar.zoomToPrevExtent();">Prev Extent</div>
    <div dojoType="dijit.form.Button" id="zoomnext" iconClass="zoomnextIcon" onClick="navToolbar.zoomToNextExtent();">Next Extent</div>
    <!-- <div dojoType="dijit.form.Button" id="pan" iconClass="panIcon" onClick="navToolbar.activate(esri.toolbars.Navigation.PAN);">Pan</div> -->
    <div dojoType="dijit.form.Button" id="deactivate" iconClass="panIcon" onClick="navToolbar.deactivate()">Pan</div>
  </div>
  <div style="position:absolute; right:70px; top:10px; z-Index:999;">
        <div dojoType="dijit.TitlePane" title="Switch Basemap" closable="false"  open="false">
          <div dojoType="dijit.layout.ContentPane" style="width:380px; height:280px; overflow:auto;">
          <div id="basemapGallery" ></div></div>
        </div></div>
    <div id="content" dojotype="dijit.layout.BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;">
      <div id="rightPane" dojotype="dijit.layout.ContentPane" region="right">
        <div dojoType="dijit.layout.AccordionContainer">
          <div dojoType="dijit.layout.ContentPane" id="legendPane" title="Legend"  selected="false">
            <div id="legendDiv"></div>
          </div>
          <div dojoType="dijit.layout.ContentPane" title="Frederick County GIS Layers" selected="true">
            <span style="padding:10px 0;">Click to toggle the visibilty of different Layers.</span><br /><br />
            <div id="toggle" style="padding: 2px 2px; font-size:10px;"></div>
          </div>
    <div dojoType="dijit.layout.ContentPane" title="Search Tools" selected="false">
   <span style="padding:10px 0;">Coming Soon!</span>
     PIN Lookup: <input type="text" id="PARCELID" size="20" value="54    A    25" />
     <input type="button" value="Search" onclick="doFind();" /><br />
     <div id="loading"><img src="http://help.arcgis.com/en/webapi/javascript/arcgis/demos/map/images/loading.gif" /></div>
   </div>
        </div>
      </div>
      <div id="map" dojotype="dijit.layout.ContentPane" style="width: 77%; height: 85%;" region="center" style="overflow:hidden;">
      </div>
   <div id="scalebar" style="position:absolute;left:15px;top:84%;"></div>
   <div dojotype="dijit.layout.ContentPane" region="bottom" style="position:absolute;left:5px;top:88%;height:10%;width:77%">
    <table dojoType="dojox.grid.DataGrid" jsid="grid" id="grid" rowsPerPage="4" rowSelector="10px">
      <thead>
        <tr>
          <th field="RECNUM" width="15%">PIN</th>
          <th field="MLNAM" width="15%" >Owner 1</th>
          <th field="MFNAM" width="15%">Owner 2</th>
          <th field="MADD1" width="25%">Mailing Address</th>
          <th field="MADD2" width="30%">Zip</th>
        </tr>
      </thead>
    </table>
    </div>
  </div>
  </body>
ADD - here is the web address... http://www.co.frederick.va.us/planning/newmap1copy2.html
TonyAlmeida
MVP Regular Contributor
When i click on the link all i see is the application with your data, but no source code. I would like to see how you put all the code together.
AlexGray
Open the application in your browser again.. move the mouse to the top of the page above the map.. RIGHT-Click on the mouse... you should see a menu pop-up... CLICK - 'view page source'.. You should then be able to see all the source code.. then all you need to do is select it all and copy it and paste it into the editor of your choice..
If you can't do that.. then please respond again and I will zip it up.. and attach the code.. I can't post the entire code in the forum because it extends beyond the limits of the forum..
Good Luck..
TonyAlmeida
Right!
Thanks.
