How do I get the first array item and then first array item value from my array?
6423
11
06-22-2015 02:27 PM
ChrisSergent
Here is a code sample that I have that acquires an array of values:
JS Bin - Collaborative JavaScript Debugging
There are signs that display  the following. I need to get the objectID from the first sign, and then the installed value and then signId and so on. Then I would go to the next item in the array on button click. How would I do that?
OBJECTID: 9263
INSTALLED: null
SIGNID: 1169
FACING: S
VISIBILITY: Good
CONDITION_: Good
SUPPORTID: 691
TEXT:
COLOR1:
DELINEATOR: None
ILLUM: None
OFFSET: null
MOUNTHT: null
BACKING: Aluminum
WIDTH: null
HEIGHT: null
TXTSIZE: null
NUMSIZE: null
COMMENTS:
TWOSIDED: Y
ATTACHTYPE: Bolts
ATTACHNUM: null
ATTACHLOC: Main pole
SITEOBS: Clear
SIGNSHAPE:
COLOR2:
MUTCD: R1-1 (Stop Sign)
GLOBALID: {34E39E75-F785-4272-8F2E-7A13349817F0}
OBJECTID: 9264
INSTALLED: null
SIGNID: 1168
FACING: E
VISIBILITY: Good
CONDITION_: Good
SUPPORTID: 691
TEXT:
COLOR1:
DELINEATOR: None
ILLUM: None
OFFSET: null
MOUNTHT: null
BACKING: Aluminum
WIDTH: null
HEIGHT: null
TXTSIZE: null
NUMSIZE: null
COMMENTS:
TWOSIDED: Y
ATTACHTYPE: Other
ATTACHNUM: null
SITEOBS: Clear
SIGNSHAPE:
COLOR2:
MUTCD: D3-1 (Street sign) - Street Name & Parking Signs
GLOBALID: {C8253B28-2EEA-43B2-BFB0-2F1658741E45}
OBJECTID: 9265
INSTALLED: null
SIGNID: 1167
FACING: N
VISIBILITY: Good
CONDITION_: Good
SUPPORTID: 691
TEXT:
COLOR1:
DELINEATOR: None
ILLUM: None
OFFSET: null
MOUNTHT: null
BACKING: Aluminum
WIDTH: null
HEIGHT: null
TXTSIZE: null
NUMSIZE: null
COMMENTS:
TWOSIDED: Y
ATTACHTYPE: Other
ATTACHNUM: null
SITEOBS: Clear
SIGNSHAPE:
COLOR2:
GLOBALID: {75AE4A49-7A0E-48B0-A6DD-4FB318BFFC27}
OBJECTID: 22205
INSTALLED: null
SIGNID: 1169
FACING: S
VISIBILITY: Good
CONDITION_: Good
SUPPORTID: 691
TEXT:
COLOR1:
DELINEATOR: None
ILLUM: None
OFFSET: null
MOUNTHT: null
BACKING: Aluminum
WIDTH: null
HEIGHT: null
TXTSIZE: null
NUMSIZE: null
COMMENTS:
TWOSIDED: Y
ATTACHTYPE: Bolts
ATTACHNUM: null
SITEOBS: Clear
SIGNSHAPE:
COLOR2:
GLOBALID: {D0188C14-D518-42BE-B36E-CCEDB4474BD3}
I have managed to get the first letter of an attribute to increment however:
 on(dom.byId("btnSupportNext"),"click",function(){
            console.log("Next Works");
            var query = new esriQuery();
            var queryTask = new QueryTask(config.signLayerUrl);
            query.returnGeometry = false;
            query.outFields = ["*"];
            query.where = "SUPPORTID = " + dom.byId("supportId").value;
            queryTask.execute(query, function (results) {
                // Attempting to know how many signs are in my results
                // Use gettArray.html to get array values
                console.log("Results start now!");
                console.log(results);
                var resultItems = [];
                var resultCount = results.features.length;
                for (var i = 0; i < resultCount; i++) {
                    var featureAttributes = results.features.attributes.ATTACHLOC;
                    for (var attr in featureAttributes) {
                        console.log("Attribute: " + featureAttributes[attr]);
thejuskambi
Adding to what Darren has mentioned. If you can hold the query result also a part of Global variable, so that you dont have to make a request to server every time. Query once when you open the dialog/form and clear it when you close the dialog/form.
ChrisSergent
Good call. I added the variable reset on form opening.
