How do I change double-click to cntl-click to activate drawend.
1418
10-09-2013 11:27 AM
ThomasRoussell
User's find it annoying when they accidently double click when using the polyline draw tool. Is it possible to change "double-click to end" to "cntrl-click to end" when using drawToolbar.activate(esri.toolbars.Draw.POLYLINE);
JasonZou
You will need to disconnect the default event handlers for onClick and onDoubleClick, and define your own version of onClick event handler. Here is the sample which I tested working, assuming two things: code in legacy mode and the drawToolbar and map objects are global variables.
drawToolbar.activate(esri.toolbars.Draw.POLYLINE); dojo.disconnect(drawToolbar._onDblClickHandler_connect); dojo.disconnect(drawToolbar._onClickHandler_connect); drawToolbar._onClickHandler_connect = dojo.connect(map, "onClick", onMapClick);  function onMapClick(evt) {     if (evt.ctrlKey) {         drawToolbar._onDblClickHandler(evt);    // end draw operation     }     else {         drawToolbar._onClickHandler(evt);    // normal draw operation     } }
JasonZou
ThomasRoussell
Thanks Jason. That works great!!!!
