How do I auto-size an infoWindow?
1741
06-22-2010 03:54 AM
AndrewClark
Hopefully someone out there as this one sused. if so, please tell me how?!!?!
HallbjornViktorsson
Not sure if your still looking for this but this might at lest help other that are in your shoes if you found the answer
dojo.connect(map,"onLoad", function(map) {map.infoWindow.resize(250, 100);} );
map.infoWindow.resize(250,100); <- Her you can determine the size of your info box, Hope this helps.
AndrewClark
Not quite what I was looking for but I found a solution;
Basically, I set the content of the infowindow and measured the outer-most tag (in my case a table), then used these measurements with some padding to account for the rest of the dialog, to set the size of the infowindow. It also helped converting spaces in text to " "'s.
cosophy
I�??ve been looking for it too!
I just want to dynamically set the size of the infowindow based on its content data size, but i do not quite understand your solution, could you give some sample code ?
RaviKonaparthi
If you content is dynamic, then use dojo.coords() function to get the dimensions of the table(dynamic content) and accordingly resize the infowindow so that the content will adjust as per the content.
Regards,
Ravi.
